Remote management using maapi
botero22496
Visitor
I little question. Is it possible to get or modify CDB information of a remote NSO server using MAAPI?.
thanks
vleijon
Yes, it is possible. You just change the IPC listen address.
There are security aspects though, anyone with access to the IPC port can do anything they want with the system.
