rest call to initiate a Yang action - how to send in inputs.
previousqna
Level 5
Level 5
I wanted to have a rest call to initiate a yang action:
container  GWServiceValidation {
      description "Gateway service validation";
      tailf:action validate-gwservice {
        tailf:info "Validate SAEGW/MME gateway standalone";
        tailf:actionpoint GWService-validation-point;
                input {
                        leaf device {
                        type leafref {
                           path "/ncs:devices/ncs:device/ncs:name";
                        leaf gw_type {
                                type enumeration {
                                        enum SAEGW;
                                        enum MME;
        output {
          uses action-output;
So I used a post command as follows – but get that device cannot be a child. Can anyone point me quickly to the correct syntax to provide the leaf parameters into the action?
previousqna
Level 5
Level 5
I believe you need an <input> element around the parameters.
previousqna
Level 5
Level 5
Your request pay load on the screen shot is actually not a valid XML file since it doesn’t have root.
I can’t verify, but a valid payload may be something look like this:
<?xml version="1.0" encoding="UTF-8" ?>
                <input>
                                < device >mano</device>
                                < gw_type >MME</ gw_type >
                </input>
Good luck!
[NAME] sent same and it worked!
