10-18-2018 12:55 PM - edited 10-18-2018 03:19 PM
Is there a way to get the device "name" using "address"?
GET /api/running/devices/device?select=name;address
gives
{ "collection": { "tailf-ncs:device": [
{"name": "DEVICE1","address": "1.1.1.1" },
{"name": "DEVICE2","address": "2.2.2.2" }
Looking something like
GET /api/running/devices/device?select=name;address=2.2.2.2
or
GET /api/running/devices/device[address=2.2.2.2]
But no luck. Tried also RESTCONF using "fields=name;address", again, no way to specify a value for address.
Solved! Go to Solution.
10-19-2018 06:14 AM
Thanks to an NSO expert, here is a great answer, in case anyone else needs the same:
curl -i 'http://admin:admin@localhost:8080/api/query' -X POST -T q.json -H "Content-Type: application/vnd.yang.data+json"
where file q.json is
"immediate-query": {
"foreach": "/devices/device[address = '2.2.2.2']",
"select": [
"expression": "name",
"result-type": ["string"]
"expression": "address",
"sort-by": ["name"],
"limit": 100,
"offset": 1
10-19-2018 06:14 AM
"select": [
"limit": 100,
"offset": 1
