RESTCONF PATCH behaviour
LK2401
Frequent Visitor
Frequent Visitor
Is the difference in behaviour on these two restconf requests intended?
Platform is NSO 4.7.x
The first will produce 500 Internal Server - the latter works as expected.
  "ietf-yang-patch:yang-patch":{
    "patch-id":"deleteitnowplease",
    "edit":[
        "operation":"delete",
        "target":"/loopback-service:loopback-service=test1242",
	"edit-id":"remove-test"
    "edit":[
	"edit-id":"remove-test",
"target":"/loopback-service:loopback-service=test1242", } ] } }
tsiemers1
If you are below 4.7.4.1 they did have an error that produced the 500 response.
- restconf: Corrected the body format of yang-patch-status response
    message in success cases.
    (ENG-20606, RT:36346, PS-31425)
https://community.cisco.com/t5/nso-developer-hub-discussions/yang-patch-response/td-p/3900972
LK2401
Frequent Visitor
Frequent Visitor
Both 4.7.7.4 and 4.7.7.6 gives me error 500
perander
This seems to be a bug actually. I have created an internal ticket for it.
Specifically, JSON encoding of lists [0] states that:
   Unlike the XML encoding, where list keys are required to precede any
   other siblings within a list entry and appear in the order specified
   by the data model, the order of members in a JSON-encoded list entry
   is arbitrary because JSON objects are fundamentally unordered
   collections of members.
[0]  https://tools.ietf.org/html/rfc7951#section-5.4
