Yang Patch response
tsiemers1
Testing out trying to use yang-patch (rfc 8072) for pushing two edits of the same service in one restconf call. I can get the yang-patch to work fine and it creates two services and commits them with the one call.
The problem I am running into is not getting a response from yang-patch. Per the RFC section 2.6:
If a YANG Patch is completed without errors, the RESTCONF server MUST
   return a "yang-patch-status" message with a "global-status" choice
   set to "ok".
   Refer to Appendix A.1.2 for an example of a successful YANG Patch
   response.
Currently with postman, curl, or python calls I am getting 500 internal errors.
Am I missing a step that will show the yang-patch-status? Attached is yang, below the restconf call.
RESTCONF: (Shell Curl)
curl --request PATCH \
  --url http://ncslab.com:8080/restconf/data/patch-service-test \
  --header 'Accept: application/yang-data+json' \
  --header 'Authorization: Basic daaaaaaaaaaaaa2Ux' \
  --header 'Content-Type: application/yang-patch+json' \
  --data 'service_patch.json'
service_patch.json
  "ietf-yang-patch:yang-patch": {
    "patch-id": "patch-1",
    "comment": "Test Patch responses",
    "edit": [
        "edit-id": "edit1",
        "operation": "create",
        "target": "/",
        "value": {
          "patch-service-test:patch-service-test": [
              "patch-service-test:circuit_id": "patch_yang_CID_1",
              "patch-service-test:name": "patch_description1",
              "patch-service-test:deviceName": "xe_virl",
              "patch-service-test:deviceID": "1111",
              "patch-service-test:deviceType": "cisco-ios",
              "patch-service-test:interfaceType": "GigabitEthernet",
              "patch-service-test:interfaceName": "0/0/0"
        "edit-id": "edit2",
        "target": "/",
        "value": {
              "patch-service-test:circuit_id": "patch_yang_CID_2",
              "patch-service-test:name": "patch_description2",
The server just responds with the following:
500 Internal Server Error
Logs from NSO just show the service being created and a commit performed by rest.
Can more verbose logging be turned on or something added to the restconf call to get the response part working?
lmanor
Can you provide the NSO Version?? Thx.
4.7.3.1
tsiemers1
Just upgraded to 4.7.4.3, saw in changelog this was fixed in 4.7.4.1. Works now.
- restconf: Corrected the body format of yang-patch-status response
    message in success cases.
    (ENG-20606, RT:36346, PS-31425)
