Service model context setting issue
previousqna
Level 8
Level 8
I have a pretty simple L2VPN service model that I’m trying to debug but having a problem. The problem is I reference the interface name under bridge-domain and it inserts the interface from both links into each device config.
Below is
  • The config
  • Commit dryrun including a snipet from debug template
  • Yang file
  • Xml template
Config –
admin@ncs(config)# show conf
services l2vpnSRservice customer-400
bridge-group-name  customers
bridge-domain-name customer-400
vpn-id             400
signaling-protocol ldp
rd-id              1.1.1.1:400
rt-id              1.1.1.1:400
link asr-9001-a
intf-number 0/0/0/1.400
  vlan-id     400
link asr-9001-b
intf-number 0/0/0/0.400
  vlan-id     400
The problem is I reference the interface name under bridge-domain and it inserts the interface from both links – highlighted in read below –
Commit dryrun –
admin@ncs(config)# commit dry-run
cli {
    local-node {
        data  devices {
                  device asr-9001-a {
config {
cisco-ios-xr:interface {
GigabitEthernet-subinterface {
             +                    GigabitEthernet 0/0/0/1.400 {
             +                        mode l2transport;
             +                        encapsulation {
             +                            dot1q {
             +                                vlan-id [ 400 ];
             +                        rewrite {
             +                            ingress {
             +                                tag {
             +                                    pop 1;
             +                                    mode symmetric;
cisco-ios-xr:l2vpn {
bridge {
                                  group customers {
             +                        bridge-domain customer-400 {
            + interface GigabitEthernet0/0/0/0.400;
             +                            interface GigabitEthernet0/0/0/1.400;
             +                            vfi customer-400 {
             +                                vpn-id 400;
             +                                autodiscovery {
             +                                    bgp {
             +                                        rd 1.1.1.1:400;
             +                                        route-target {
             + route-target-list 1.1.1.1:400;
             + signaling-protocol {
             +                                            ldp {
device asr-9001-b {
config {
             +                    GigabitEthernet 0/0/0/0.400 {
             +                        mode l2transport;
             +                        encapsulation {
             +                            dot1q {
             +                                vlan-id [ 400 ];
             +                        rewrite {
             +                            ingress {
             +                                tag {
             +                                    pop 1;
             +                                    mode symmetric;
bridge {
                                  group customers {
             +                                vpn-id 400;
             +                                autodiscovery {
             +                                    bgp {
             +                                        rd 1.1.1.1:400;
             + route-target {
             +                                            ldp {
              services {
             +    l2vpnSRservice customer-400 {
             +        bridge-group-name customers;
             +        bridge-domain-name customer-400;
             +        vpn-id 400;
             +        signaling-protocol ldp;
             +        rd-id 1.1.1.1:400;
             +        rt-id 1.1.1.1:400;
             +        link asr-9001-a {
             +            iosxr {
             +                intf-number 0/0/0/1.400;
             +                vlan-id 400;
             +        link asr-9001-b {
             +            iosxr {
             +                intf-number 0/0/0/0.400;
             +                vlan-id 400;
admin@ncs(config)# commit dry-run | debug temp
Operation 'merge' on existing node: /devices/device[name='asr-9001-a']/config/cisco-ios-xr:l2vpn (from file "l2vpnSRservice-template.xml", line 32)
Evaluating "/bridge-group-name" (from file "l2vpnSRservice-template.xml", line 35)
Context node: /services/l2vpnSRservice:l2vpnSRservice[vfi-name='customer-400']/link[device='asr-9001-a']
Result:
For /services/l2vpnSRservice:l2vpnSRservice[vfi-name='customer-400'], it evaluates to "customers"
Operation 'merge' on existing node: /devices/device[name='asr-9001-a']/config/cisco-ios-xr:l2vpn/bridge/group[group-name='customers'] (from file "l2vpnSRservice-template.xml", line 35)
Evaluating "bridge-domain-name" (from file "l2vpnSRservice-template.xml", line 37)
Result:
For /services/l2vpnSRservice:l2vpnSRservice[vfi-name='customer-400'], it evaluates to "customer-400"
Operation 'merge' on non-existing node: /devices/device[name='asr-9001-a']/config/cisco-ios-xr:l2vpn/bridge/group[group-name='customers']/bridge-domain[bridge-domain-name='customer-400'] (from file "l2vpnSRservice-template.xml", line 37)
Fetching literal "GigabitEthernet" (from file "l2vpnSRservice-template.xml", line 39)
Evaluating "/link/iosxr/intf-number" (from file "l2vpnSRservice-template.xml", line 39)
Result:
For /services/l2vpnSRservice:l2vpnSRservice[vfi-name='customer-400']/link[device='asr-9001-a']/iosxr, it evaluates to "0/0/0/1.400"
For /services/l2vpnSRservice:l2vpnSRservice[vfi-name='customer-400']/link[device='asr-9001-b']/iosxr, it evaluates to "0/0/0/0.400"
Operation 'merge' on non-existing node: /devices/device[name='asr-9001-a']/config/cisco-ios-xr:l2vpn/bridge/group[group-name='customers']/bridge-domain[bridge-domain-name='customer-400']/interface[name='GigabitEthernet0/0/0/1.400'] (from file "l2vpnSRservice-template.xml", line 39)
Operation 'merge' on non-existing node: /devices/device[name='asr-9001-a']/config/cisco-ios-xr:l2vpn/bridge/group[group-name='customers']/bridge-domain[bridge-domain-name='customer-400']/interface[name='GigabitEthernet0/0/0/0.400'] (from file "l2vpnSRservice-template.xml", line 39)
Yang file –
module l2vpnSRservice {
      namespace "http://com/example/l2vpnSRservice";
      prefix l2vpnSRservice;
      import ietf-inet-types { prefix inet; }
      import tailf-ncs { prefix ncs; }
      import tailf-common { prefix tailf; }
      import tailf-ned-cisco-ios {prefix ios;}
      import tailf-ned-cisco-ios-xr {prefix cisco-ios-xr;}
      augment /ncs:services {
      list l2vpnSRservice {
            description "This is a L2VPN service.  The service uses BGP autodiscovery to find the relevant PEs and configures an IOS-XR or an IOS-XR router to act as an L2VPN PE.";
                   key vfi-name;
                   uses ncs:service-data;
                    ncs:servicepoint l2vpnSRservice-servicepoint;
                   leaf customer {
                          type leafref {
                                 tailf:info "L2VPN Customer";
                                path "/ncs:customers/ncs:customer/ncs:id";
                   leaf bridge-group-name {
                          mandatory true;
                          type string;
                           tailf:info "Bridge Group Name";
                   leaf bridge-domain-name {
                          mandatory true;
                           tailf:info "Bridge Domain Name";
                          type string;
                   leaf vfi-name {
                          mandatory true;
                           tailf:info "VFI Name";
                          type string;
                   leaf vpn-id {
                          mandatory true;
                           tailf:info "VPN ID";
                          type uint32;
                   leaf signaling-protocol {
                          mandatory true;
                           tailf:info "Signaling Protocol";
                          type enumeration {
                                enum bgp;
                                enum ldp;
                   leaf rd-id {
                          mandatory true;
                           tailf:info "Unique RD ID xxx:xxx";
                          type ios:asn-ip-type;
                   leaf rt-id {
                          mandatory true;
                           tailf:info "Route-target";
                   list link {
                           tailf:info "CE Facing Interface";
                          min-elements 1;
                          max-elements 10;
                          key device;
                          leaf device {
                                 tailf:info "PE Router";
                                mandatory true;
                                type leafref {
                                       path "/ncs:devices/ncs:device/ncs:name";
                          container iosxr {
                                  tailf:cli-drop-node-name;
                                when"/ncs:devices/ncs:device[ncs:name=current()/../device]/ncs:device-type/ncs:cli/ncs:ned-id='cisco-ios-xr-id:cisco-ios-xr'";
                                leaf existing-iosxr-intfs {
                                        tailf:info "Review list of existing GigabitEthernet interfaces -- read only";
                                       type leafref {
                                              path"/ncs:devices/ncs:device[ncs:name=current()/../../device]/ncs:config/cisco-ios-xr:interface/cisco-ios-xr:GigabitEthernet/cisco-ios-xr:id";
                                leaf existing-iosxr-subintfs {
                                        tailf:info "Review list of existing GigabitEthernet sub-interfaces -- read only";
                                       type leafref {
                                              path"/ncs:devices/ncs:device[ncs:name=current()/../../device]/ncs:config/cisco-ios-xr:interface/cisco-ios-xr:GigabitEthernet-subinterface/cisco-ios-xr:GigabitEthernet/cisco-ios-xr:id";
                                leaf intf-number {
                                        tailf:info "GigabitEthernet interface ID including .x";
                                       mandatory true;
                                       type string;
                                leaf vlan-id {
                                        tailf:info "Subinterface vlan id";
                                 mandatory true;
                                type uint16 {
range "1 .. 4084" {
error-message "Vlan range 1-4094";
                                leaf ve-id {
                                        tailf:info "VE-ID.  Note: required with BGP signaling only";
                                       type uint16;
                                leaf vpls-id {
                                        tailf:info "VPLS-ID.  Note: optional with BGP signaling only";
                           tailf:action self-test {
                           tailf:info "Perform self-test of the service";
                          tailf:actionpoint l2vpnSRservice-self-test;
                          output {
leaf success {
type boolean;
leaf message {
type string;
description "Free format message.";
XML –
<?xml version="1.0" encoding="utf-8"?>
<config-template xmlns="http://tail-f.com/ns/config/1.0">
      <devices xmlns="http://tail-f.com/ns/ncs">
            <devicetags="nocreate">
                   <!-- Get Device name -->
                   <name>{/link/device}</name>
                   <config tags="merge">
                          <!-- IOS-XR Device -->
                          <!-- Configure IOS-XR Device -->
                   <!-- Configure IOS-XR Device interface -->
                   <interface xmlns="http://tail-f.com/ned/cisco-ios-xr"tags="merge">
                   <GigabitEthernet-subinterface when="{iosxr/intf-number}">
                                <GigabitEthernet>
                                <id>{iosxr/intf-number}</id>
                                <mode>l2transport</mode>
                                <encapsulation>
                                             <dot1q>
                                                           <vlan-id>{vlan-id}</vlan-id>
                                             </dot1q>
                                </encapsulation>
                                <rewrite>
                                             <ingress>
                                             <tag>
                                                    <pop>1</pop>
                                                    <mode>symmetric</mode>
                                             </tag>
                                             </ingress>
                                </rewrite>
                                </GigabitEthernet>
                          </GigabitEthernet-subinterface>
                   </interface>
                   <l2vpn xmlns="http://tail-f.com/ned/cisco-ios-xr" tags="merge">
                         <bridge>
                                <group>
                                <group-name>{/bridge-group-name}</group-name>
                                <bridge-domain>
                                             <bridge-domain-name>{bridge-domain-name}</bridge-domain-name>
                                             <interface>
                                                    <name>GigabitEthernet{/link/iosxr/intf-number}</name>
                                             </interface>
                                     <vfi>
                                             <name>{vfi-name}</name>
                                             <vpn-id>{vpn-id}</vpn-id>
                                             <autodiscovery>
                                                    <bgp>
                                                          <rd>{rd-id}</rd>
                                                          <route-target>
        <route-target-list>
        <name>{rt-id}</name>
        </route-target-list>
                                                          </route-target>
                                                          <signaling-protocol>
        <ldp>
                                                          <vpls-id>{vpls-id}</vpls-id>
                                                          </ldp>
                                                          </signaling-protocol>
                                                    </bgp>
                                             </autodiscovery>
                                             </vfi>
                                </bridge-domain>
                                       </group>
                         </bridge>
                   </l2vpn>
            </config>
            </device>
      </devices>
</config-template>
previousqna
Level 8
Level 8
Looks like I missed the obvious on this  --
<interface>
              <name>GigabitEthernet{/link[device=$DEVICE]/iosxr/intf-number}</name>
</interface>
previousqna
Level 8
Level 8
<interface>
</interface>
