result false info internal error
previousqna
Level 5
Level 5
I have a JunOS device which I cannot connect to. I had just added it and succesfully fetched the host keys for SSH, then ran into a few problems connecting from NSO via SSH ("...Subsystem not supported..." and Authentication problems). I played around with the SSH settings on the JunOS (set SSH v1 and activated root-authentication and created appropriate user mapping in NSO). I had then connected successfully once to the device and went for lunch. When I got back and tried to connect again I got the error
Unfortunately the error message doesnt give much information on what happens:
From the ncs_cli I try to connect and get this:
admin@ncs# devices device JunOS connect
result false
info internal error
admin@ncs#
From the WebUI I get pretty much the same. See attached screenshot.
I am using the following NED for Juniper: juniper-junos version: 3.0.27
I tried to have a look in the logs, but there isnt really much more info to be found there either (I checked ncs.log to no avail but found sth. in devel.log, where I can see my attempts to connect, but not much more info on what is causing the error). Here is a short excerpt from the log (I think it is from one of the connect attempt via the webUI):
<INFO> 11-Oct-2016::15:20:19.828 osboxes ncs[2122]: ncs failed to connect to JunOS: noconnection
<DEBUG> 11-Oct-2016::15:20:19.830 osboxes ncs[2122]: devel webui_appmod_jsonrpc
REQUEST sessST6hiwA2gZo447egesudbA==: {"jsonrpc":"2.0","id":69,"method":"run_action","params":{"th":1,"path":"/ncs:devices/device{\"JunOS\"}/connect"}}
RESPONSE sessST6hiwA2gZo447egesudbA==: {"jsonrpc":"2.0","result":[{"name":"result","value":"false"},{"name":"info","value":"internal error"}],"id":69}
Any idea what could cause this error and how to go about resolving it?
P.S.: I tried restarting ncs completely which didn't help.
Attached file: https://communities.cisco.com/servlet/JiveServlet/download/231916-129797/image.png
previousqna
Level 5
Level 5
OK...I set the SSH version back to v2 (default) on the JunOS. The I kept getting "info Failed to authenticate towards device JunOS: SSH subsystem not supported".
I needed to activate the SSH Subsystem by entering the following commands in JunOS cli:
configure
edit system services
set netconf ssh
set ssh
Now I managed to connect again. Still not sure what happened during my lunch break as I believe I had connected succesfully once. anyway, now it seems to work.
previousqna
Level 5
Level 5
configure
set netconf ssh
set ssh
