Set tailf:cli-reset-siblings values using a config-template
mikeg22
YANG values with tailf:cli-reset-siblings require mutliple values be set in the same "pass". A device-template will do so. For example:
admin@7ccbd23a9e56(config)# devices template set_radius_server_ipv4_ports ned-id cisco-ios-cli-6.84 config
admin@7ccbd23a9e56(config-config)# radius server TEST address ipv4 auth-port 1234 acct-port 5678
admin@7ccbd23a9e56(config-server-TEST)# commit
Commit complete.
admin@7ccbd23a9e56(config-server-TEST)# top
admin@7ccbd23a9e56(config)# devices device functional-gns3-sw1 apply-template template-name set_radius_server_ipv4_ports | debug template
Operation 'merge' on existing node: /devices/device[name='functional-gns3-sw1']
Fetching literal "TEST"
Operation 'merge' on non-existing node: /devices/device[name='functional-gns3-sw1']/config/ios:radius/server[id='TEST']
Operation 'merge' on non-existing node: /devices/device[name='functional-gns3-sw1']/config/ios:radius/server[id='TEST']/address/ipv4/auth-port
Fetching literal "1234"
Setting /devices/device[name='functional-gns3-sw1']/config/ios:radius/server[id='TEST']/address/ipv4/auth-port to "1234"
Operation 'merge' on non-existing node: /devices/device[name='functional-gns3-sw1']/config/ios:radius/server[id='TEST']/address/ipv4/acct-port
Fetching literal "5678"
Setting /devices/device[name='functional-gns3-sw1']/config/ios:radius/server[id='TEST']/address/ipv4/acct-port to "5678"
apply-template-result {
result ok
admin@7ccbd23a9e56(config)# commit dry-run
cli {
  local-node {
    data devices {
      device functional-gns3-sw1 {
        config {
          radius {
          + server TEST {
          +   address {
          +     ipv4 {
          +       auth-port 1234;
          +       acct-port 5678;
admin@7ccbd23a9e56(config)# commit dry-run outformat xml
result-xml {
  local-node {
    data <devices xmlns="http://tail-f.com/ns/ncs">
      <device>
        <name>functional-gns3-sw1</name>
        <config>
          <radius xmlns="urn:ios">
            <server>
              <id>TEST</id>
              <address>
                <ipv4>
                  <auth-port>1234</auth-port>
                  <acct-port>5678</acct-port>
                </ipv4>
              </address>
            </server>
          </radius>
        </config>
      </device>
    </devices>
But applying the above XML in a config-template only sets acct-port:
+ server TEST_SERVER {
+   address {
+     ipv4 {
+       host ###.###.2.62;
+       acct-port 1813;
How can I set multiple values with an XML config-template when the value's YANG has tailf:cli-reset-siblings?
mikeg22
My understanding of tailf:cli-reset-siblings was incomplete and I misdiagnosed the cause of my config-template problem. A better understanding of tailf:cli-sequence-commands/tailf:cli-reset-siblings (provided by a Cisco Engineer) allowed me to find and fix the root cause of my issue.
A config-template can set tailf:cli-reset-siblings values. My template uses XPaths for the acct/auth-port values and I inadvertantly reset auth-port by not knowing the tailf:cli-sequence-commands/tailf:cli-reset-siblings requirements.
hniska
You also need to set the host part
Juniper cli
set devices device ce0 config radius server test address ipv4 acct-port 1234 auth-port 3214 host 192.168.1.1
Cisco cli
admin@ncs(config)# show full-configuration devices device ce0 config radius
devices device ce0
config
radius server test
address ipv4 192.168.1.1 auth-port 3214 acct-port 1234
hniska, thank you for replying! I am getting the same behavior while specifying the host:
admin@7ccbd23a9e56(config-config)# radius server TEST address ipv4 host ###.###.4.62 auth-port 1234 acct-port 5678
Commit complete.
Operation 'merge' on non-existing node: /devices/device[name='functional-gns3-sw1']/config/ios:radius/server[id='TEST']/address/ipv4/host
Fetching literal "###.###.4.62"
Setting /devices/device[name='functional-gns3-sw1']/config/ios:radius/server[id='TEST']/address/ipv4/host to "###.###.4.62"
  result ok
cli {
  local-node {
    data devices {
        config {
          radius {
+           server TEST {
+             address {
+               ipv4 {
+                 host ###.###.4.62;
+                 auth-port 1234;
+                 acct-port 5678;
result-xml {
  local-node {
      <device>
        <config>
            <server>
              <id>TEST</id>
              <address>
                <ipv4>
                  <host>###.###.4.62</host>
                </ipv4>
              </address>
            </server>
          </radius>
        </config>
      </device>
    </devices>
+     address {
+       ipv4 {
+         acct-port 1813;
mikeg22
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
