Subscribe to specific path on cdb
sfloresk
Is there a way to subscribe to a specific path in the cdb using netconf? For example, this code works, but returns all changes
import ncclient.manager
m = ncclient.manager.connect_ssh(host="localhost",
port=2022,
username="****",
password="***",
hostkey_verify=False,
timeout=120, look_for_keys=False)
m.create_subscription(stream_name="NETCONF")
print('Listening notifications from NSO (stream ncs-events)')
while True:
# This will block until a notification is received because
# we didn't pass a timeout or block=False
n = m.take_notification()
print(n.notification_xml)
When I try to create the same subscription, but only for devices with xpath filter:
port=2022,
username="****",
password="*****",
m.create_subscription(stream_name="NETCONF", filter=("xpath","/devices/device"))
while True:
I get the following error:
ncclient.operations.rpc.RPCError: {'type': 'protocol', 'tag': 'unknown-element', 'app_tag': None, 'severity': 'error', 'info': '<?xml version="1.0" encoding="UTF-8"?><error-info xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:nc="urn:ietf:params:xml:ns:netconf:base:1.0"><bad-element>filter</bad-element>\n</error-info>\n', 'path': '\n /rpc/p0:create-subscription\n ', 'message': None}
Thank you
sfloresk
It can be done using yang push - IETF RFC 8641
sfloresk
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
