Sync-from as load-merge
tsiemers1
Is it possible to trigger a sync-from or action from load-merge? We have a service that needs to wait until a maintenance window to be pushed. The thought was to have a few load-merge files ready to go for the person running the maintenance window. One XML that has a list of devices that needs to be sync'd before. Then another that after they sync'd runs the service. I have tried the following looking at the tailf:action sync-from and was not able to get it to work:
XML:
<?xml version="1.0" ?>
<devices xmlns="http://tail-f.com/ns/ncs">
  <device>
    <name>Device1</name>
     <sync-from></sync-from>
  </device>
</devices>
Not sure if this is designed to work this way since a load-merge would kick off the action right away.
rogaglia
load merge would be used to load data into CDB. "Sync-from" is an RPC/Action and not something you store in CDB. So, to you question, the answer would be no.
Moreover, your idea does not sound like a safe operational process. What I would suggest you is to set a service state leaf and some service level action. In that sense, the service is first committed but in a state that does not push config into the devices. When the device is ready, the operator would call the pre-built action via GUI/CLI/API. The action code would take care of sync-from an change the service status.
Roque
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
