sync-from with skipped lines result
paulohperes
I configured nokia sr 7750 router in nso devices (ned: alu-sr-cli-8.38) with a exists configuration and request a sync-from devices. As result some configurations output from NSO show me skipped lines, like this:
  skipped 1 line in context '/router/bgp/next-hop-resolution/labeled-routes' :
   (line 7101) : '                    allow-static'
Via webui the configuration not exists.
This problems it is related with a capabilities of the device? The yang models from version equipment exists this capabilities, how to add to nso?
Capabilities:
admin@ncs> show devices device capability
NAME URI REVISION MODULE FEATURE DEVIATION
raggpcs01 http://tail-f.com/ned/alu-sr 2023-07-13 tailf-ned-alu-sr - -
http://tail-f.com/ned/alu-sr/stats - tailf-ned-alu-sr-stats - -
http://tail-f.com/ns/ncs-ned/show-partial?path-format=cmd-path-modes-only-existing - - - -
http://tail-f.com/ns/ncs-ned/show-stats-path - - - -
urn:ietf:params:netconf:capability:with-defaults:1.0?basic-mode=report-all - - - -
[ok][2023-09-27 15:15:17]
admin@ncs>
Tks.
Nabsch
The issue is related to the NED. You should try with the latest NED 8.40.6 . If it's still not working  , you will need to open a case in order to request a NED enhacement .
Here a link that might help you
huayyang
"skipped line" usually indicates the config line from the device is not supported in the NED, you can check the skipped line is configurable from NSO CLI to verify.
As suggested by @Nabsch, If the config is missing in the latest NED, you can file an enhancement request.
