Understanding kickers
From my understanding, a kicker node is setup which points to an "action" under the node being watched. When it says node being watched, is that a single leaf node? The reason I'm asking is I'm curious if I can setup a kicker to watch an entire list, and if any leaf in that list changes, the kicker will follow up. An example of my use case is to watch everything under /devices/device/platform, so that is version or model changes for any device, it will activate the kicker. Is this possible or would it be better to have a cron job check each night to see if these values have changed since yesterday?
vleijon
It actually watches an xpath, so you can set it up to watch lists. Be aware that the behaviour for operational data depends on how the operational data is written so it will not work for all kinds of operational data.
vleijon
