Updating Pyang Inside NSO
Priya Chaturvedi
Hi there,
I am trying to use pyang for YANG module manipulation but the NSO container that I am using has pyang 1.5 which is creating issues for me as my YANG modules have version 1.1.
That's why I would like to upgrade the Pyang inside NSO. Will that cause any side-effects?
u.avsec
Not really as long as you switch NSO over to the new pyang version.
1. Install new pyang with pip
2. go to /opt/ncs/ncs-X.X.X.X/bin (NSO install dir) move pyang bin NSO comes with away and softlink pyang bin you installed with pip
In my particular case it looks like this:
root@3bb7bf86aa81:/opt/ncs/ncs-4.7.10.1/bin# ls -la pyang
lrwxrwxrwx. 1 root root 20 Jan  4 18:17 pyang -> /usr/local/bin/pyang
