Using when condition in XML template
gmathewk
Hi Team,
I am using NSO 4.6.1.3 and using this simple XML template
<config xmlns="http://tail-f.com/ns/config/1.0">
<devices xmlns="http://tail-f.com/ns/ncs">
<?set HA = 'false'?>
<device>
<name>vishal</name>
<config>
<ip xmlns="urn:ios" >
<access-list when="{$HA = 'true'}">
<standard>
<std-named-acl>
<name>CSR</name>
<std-access-list-rule>
<rule>deny any</rule>
</std-access-list-rule>
</std-named-acl>
</standard>
</access-list>
</ip>
</config>
</device>
</devices>
</config>
When i perform a load merge i get the following error:
admin@ncs% load merge test.xml
Error: on line 8: unknown attribute: when in access-list
Any idea what could be wrong ?
lmanor
the 'load merge <file>' command will directly merge the configuration contained in the xml file into the current CDB, the format of the xml file must match the yang schema.
load (merge | override) (terminal | <file>)
Load configuration from file or terminal.
merge Merge content of file/terminal with current configuration.
I don't believe processing of the 'load merge' will consider 'xml template' style processing instructions (conditionals or looping statements) as would be done by the NSO template engine for a service config-templates.
-Larry
