Validation callback in python
frjansso
Python code demonstrating a validation callback.
# -*- mode: python; python-indent: 4 -*-
import ncs
from ncs.dp import Daemon
from ncs.maapi import Maapi
from _ncs.dp import register_valpoint_cb, register_trans_validate_cb, trans_set_fd
class Validation(object):
    def __init__(self, log):
        self.log = log
        self.daemon = Daemon("foo-validation-daemon", log=log)
        self.maapi = Maapi()
        register_trans_validate_cb(self.daemon.ctx(), self)
        register_valpoint_cb(self.daemon.ctx(),
                             'the-validation-callpoint-name',
                             self)
        self.daemon.start()
    def cb_validate(self, tctx, kp, newval):
        self.log.info('validate called')
        # return ncs.CONFD_ERR to fail the validation otherwise
        # ncs.CONFD_OK
        return ncs.CONFD_OK
    def cb_init(self, tctx):
        self.maapi.attach(tctx)
        trans_set_fd(tctx, self.daemon._wsock)
    def cb_stop(self, tctx):
        self.maapi.detach(tctx)
# COMPONENT THREAD THAT WILL BE STARTED BY NCS.
class Main(ncs.application.Application):
    def setup(self):
        # The application class sets up logging for us. It is accessible
        # through 'self.log' and is a ncs.log.Log instance.
        self.log.info('Main RUNNING')
        self.v = Validation(self.log)
        # If we registered any callback(s) above, the Application class
        # took care of creating a daemon (related to the service/action point).
        # When this setup method is finished, all registrations are
        # considered done and the application is 'started'.
    def teardown(self):
        # When the application is finished (which would happen if NCS went
        # down, packages were reloaded or some error occurred) this teardown
        # method will be called.
        self.log.info('Main FINISHED')
12 Replies 12
rogaglia
Hi Fredrik,
Great example as I had this question this week.
One point that you may want to add is a description in the cb_validate() method where you clarify that there is where validation happens and which are the accepted outputs (other than CONFD_OK, I believe it is CONFD_ERR).
Finally, I was wondering what is the format for "newval" when the callback is applied to a list instead of a leaf. The values of the keys? are they comma separated?
Roque
Not sure what newval actually does, it's always 'undefined' in my tests.
If you have a list, cb_validation is called once for each list entry.
newval is supposed to hold the new value of the leaf, if the validation point is placed on a leaf. Did you try that, and if so, did you find the mechanism is broken?
Hi Jan,
Personally, that was my understanding and why I was asking how tailf:validate works on lists.
Roque
For a validation point placed on a list (or container, type empty leaf, ...) , newval will be undefined. You will need to read the value(s) you want using MAAGIC/MAAPI etc.
frjansso
Makes sense now, I never tried to att the validation point to a single leaf.
mareis
Hi Fredrik,
I'm looking for a way to return a message to the user when validation fails.
Returning ncs.CONFD_ERR I get:
admin@ncs(config-device-IOS-0)# description srt
admin@ncs(config-device-IOS-0)# commit
Aborted: application error
Which is not very user friendly.
By raising an exception I can customize a message to the user. For instance:
admin@ncs(config-device-IOS-0)# description 123
Aborted: 'services loopback device IOS-0 description': Python cb_validate error. This is not a good description
Is that the proper way to do it or is there a better option?
Marcelo
You have a python validation callback defined? Or an error message register_error_cb(...) formatter callback? Not entirely clear. Basically you can use error_seterr(...)
Hi Jan,
I have a validation callback defined, similar to the example above. It seems I can't call error_seterr from cb_validate as it expects an _ncs.UserInfo object, which I don't have within cb_validate. Would I need a register_error_cb for that?
Marcelo
mohamkh7
As per the example of above, New Daemon(Independent Thread) is registered to handle tailf:validation.
Can we attach the validation callback to existing Service(Service uses Daemon internally)
Or this is the only way exists ?
Zahid
You mean to tie the validation callback to a service class? I'm actually not sure... but I guess the question is why? 🙂
You mean to tie the validation callback to a service class? I'm actually not sure... but I guess my question is why? 🙂
