Validation failed, skip value and proceed with the NSO execution
BasharAziz
lb_ipv6_addr is an optional value, not always filled in, any idea how to skip this value and proceed with the NSO execution?
Yang:
leaf lb_ipv6_addr {
type inet:ipv6-address;
tailf:info "IPv6 loopback prefix";
Python:
vars.add('lb-ipv6-addr', f'{serivcelb_ipv6-addr}')
errors: reason: Python cb_create error. Unknown error (66): A variable value has not been assigned to: lb-ipv6-addr
XML:
<prefix>{$lb-ipv6-addr}/128</prefix>
erdemk
From other former threads , here are some options :
You may try this :
<?if {/lb-ipv6-addr != ''}?>
  <prefix>{/lb-ipv6-addr}/128</prefix>
<?end?>
or this:
<prefix tags='merge' when={/lb-ipv6-addr != ''}>{/lb-ipv6-addr}/128</prefix>
i didnot try myself this time, but you can play around with these ones.
I think you could do like following, if "/128" was not there, or you manage to get a variable somehow.. i used it like that once..
Let us know which one works for you if at all.
regards.
