frjansso
Video
A lot of what is covered here is also covered by this video: NSO-project - YouTube
The ncs-project tool
The ncs-project tool is bundled with NSO and can be used to create a new project:
# ncs-project create my-project
Creating directory: /Users/frjansso/tmp/my-project
Using NCS 4.4.2.2 found in /Users/frjansso/dev/nso-4.4.2.2
wrote project to /Users/frjansso/tmp/my-project
that generates a directory structure where NSO can be run:
# find my-project
my-project
my-project/init_data
my-project/logs
my-project/Makefile
my-project/ncs-cdb
my-project/ncs.conf
my-project/packages
my-project/project-meta-data.xml
my-project/README.ncs
my-project/setup.mk
my-project/state
# cd my-project
# ncs-project update -v -y
ncs-project: installing packages...
ncs-project: installing packages...ok
ncs-project: resolving package dependencies...
ncs-project: resolving package dependencies...ok
ncs-project: determining build order...
ncs-project: determining build order...ok
ncs-project: determining ncs-min-version...
ncs-project: determining ncs-min-version...ok
# make all start
(for i in ; do \
       /Library/Developer/CommandLineTools/usr/bin/make -C packages/${i}/src all || exit 1; \
done)
if [ ! -d ncs-cdb ]; then mkdir ncs-cdb; fi
if [ ! -d init_data ]; then mkdir init_data; fi
cp init_data/* ncs-cdb/. > /dev/null 2>&1 || true
ncs --stop || true
connection refused (stop)
ncs
So now we have NSO running in this directory, not very interesting since we don't have any packages yet.
Git
This project should be checked into git
# git init .
Initialized empty Git repository in /Users/frjansso/tmp/my-project/.git/
Now there are a bunch of files we don't want to check in, e.g. the files in logs, ncs-cdb and in state, I typically solve this using .gitignore files.
A simple such file looks like:
!.gitignore
Which tells git to ignore all files but the .gitignore files itself.
So let's create such files in logs, ncs-cdb and in state
# echo "*\n\!.gitignore" | tee logs/.gitignore ncs-cdb/.gitignore state/.gitignore
ncs-project also generates setup.mk files, I don't want to check those in to git either, so I'll create a .gitignore in the top directory to ignore those:
# echo "setup.mk*" >> .gitignore
And now we add the other files to git.
# git add .
# git status
On branch master
No commits yet
Changes to be committed:
  (use "git rm --cached <file>..." to unstage)
  new file:   .gitignore
  new file:   Makefile
  new file:   README.ncs
  new file:   logs/.gitignore
  new file:   ncs-cdb/.gitignore
  new file:   ncs.conf
  new file:   project-meta-data.xml
  new file:   state/.gitignore
  new file:   test/Makefile
  new file:   test/internal/Makefile
  new file:   test/internal/lux/Makefile
  new file:   test/internal/lux/basic/Makefile
  new file:   test/internal/lux/basic/run.lux
  new file:   test/pkgtest.env
#  git commit -am "Initial commit"
Adding local packages
A project isn't very interesting w/o any packages.
To add a local package I'll go to the packages directory and use the ncs-make-package tool
# cd packages
# ncs-make-package --service-skeleton template my-service
# git add my-service
# cd ..
To add it to the build system, I'll edit project-meta-data.xml to include my-service as a local package:
  <package>
    <name>my-service</name>
    <local/>
  </package>
I'll run ncs-project again to get the change and then build everything:
# ncs-project update -y
# make all
(for i in my-service; do \
done)
mkdir -p ../load-dir
/Users/frjansso/dev/nso-4.4.2.2/bin/ncsc  `ls my-service-ann.yang  > /dev/null 2>&1 && echo "-a my-service-ann.yang"` \
              -c -o ../load-dir/my-service.fxs yang/my-service.yang
# ncs_cli -u admin -C
admin connected from 127.0.0.1 using console on FRJANSSO-M-C1DA
admin@ncs# packages reload
>>> System upgrade is starting.
>>> Sessions in configure mode must exit to operational mode.
>>> No configuration changes can be performed until upgrade has completed.
>>> System upgrade has completed successfully.
reload-result {
    package my-service
    result true
Adding non local packages
Let's say I want to reuse another package in git, e.g. the IP address allocator:
Again I edit project-meta-data.xml:
  <packages-store>
    <git>
      <repo>ssh://[email protected]/pkg</repo>
    </git>
  </packages-store>
  <package>
    <name>ipaddress-allocator</name>
  </package>
ncs-project: found local installation of "my-service"
ncs-project: updating package ipaddress-allocator...
ncs-project: Running "cd /Users/frjansso/tmp/my-project/packages/ipaddress-allocator; git rev-parse --show-toplevel".
ncs-project: cd /Users/frjansso/tmp/my-project/packages/ipaddress-allocator
ncs-project: git stash   # (to save any local changes)
ncs-project: git checkout -q "master"
ncs-project: git fetch
ncs-project: git reset --hard origin/master
ncs-project: updating package ipaddress-allocator...done
ncs-project: checking dependencies for "ipaddress-allocator"
ncs-project: found dependency "nso-util"
ncs-project: found dependency "resource-manager"
ncs-project: git clone "ssh://[email protected]/pkg/resource-manager.git" "/Users/frjansso/tmp/my-project/packages/resource-manager"
ncs-project: git clone "ssh://[email protected]/pkg/nso-util.git" "/Users/frjansso/tmp/my-project/packages/nso-util"
ncs-project: checking dependencies for "nso-util"
ncs-project: checking dependencies for "resource-manager"
ncs-project: checking dependencies for "my-service"
# ls packages
ipaddress-allocator my-service          nso-util            resource-manager
as you can see, ncs-project pulls all the dependencies needed as well
# make all
reload-result {
    result true
reload-result {
    package my-service
    result true
reload-result {
    package nso-util
    result true
reload-result {
    package resource-manager
    result true
Keeping Git tidy
When building the packages you will get a bunch of generated files, .class, .jar, .fxs etc. Typically you don't want to check these into git, use .gitignore files to fix this.
If I run git status, I'll see this:
# git status
Untracked files:
  (use "git add <file>..." to include in what will be committed)
  .build-meta
  packages/ipaddress-allocator/
  packages/nso-util/
  packages/resource-manager/
I don't want to version control the external packages here (they have their own repo), so I'll update my .gitignore:
# echo "packages/ipaddress-allocator" >> .gitignore
# echo "packages/nso-util" >> .gitignore
# echo "packages/resource-manager" >> .gitignore
Dan.Sullivan
Great content
gschudel
Thank you Fredrik -
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
