Can not connect to ACI sandbox using anyconnect
conf-t
I'm trying to use the ACI sandbox but when I put  the "Lab Network Address: devnetsandbox-usw1-reservation.cisco.com:20128" in anyconnect vpn, an error occurred:
On Always-On Sandbox, there is an issue also; after typing the username and the password, it asks you to change the password!!!!!!!!! Help
Ruben Cocheno
@conf-t
Devnet still working on a platform refresh so access to resources might be bumpy until end of the wek.
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
That not a sandbox issue, it’s an issue with VPN. Ensure your reservation is active and showing working with no errors in the build/spin up. You can cancel the reservation and start a new one, if this happens again report to to the sandbox team here —> https://community.cisco.com/t5/devnet-sandbox/bd-p/4426j-disc-dev-devnet-sandbox
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Same issue! Could you verify with me please?
vpn_address: devnetsandbox-usw1-reservation.cisco.com:20219
username: bilel_sa
Report issue to sandbox team. In the link above.
Hope this helps.
