I have a big problem cisco packet tracer 8.0
parkj71
I turned on the Cisco packet tracker now and the screen was too big. To reduce this, I went into Options and tried to reduce the size in the application in Font and press Apply, but I can't see the application. How do I solve this? I send you a screenshot of the two problems together. I downloaded it again to solve it, but the screen is still large, so what should I do if I try to solve this problem? I would appreciate it if you could inform me of the video or how to solve it in order.
this should work for you.
https://community.cisco.com/t5/online-tools-and-resources/packet-tracer-8-0-display-problem/td-p/4388022
Good luck
rate this and mark as answer if it solved your concern
KB
Good luck
KB
jasper1927a
HOLD Ctrl key down and and  hit   either the plus sign to make big OR the  minus sign to make smaller.
Joe.
