Online Tools and Resources Tools Not Download
bdsmrahman
I am currently unable to download the files of "Online Tools and Resources". When I click on the download link provided in the free online course, a "null.htm" file downloads instead of the Packet Tracer application. See attached photo. Any help is kind. Thanks.
22 Replies 22
liviu.gheorghe
Hello @bdsmrahman ,
are you trying to download Packet tracer or Cybersecurity LabVM Workstation?
On the https://skillsforall.com/resources/lab-downloads you can download
or
The Cybersecurity LabVM Workstation, both of them, cannot be downloaded - it downloads a null.html file which I'm guessing is because of a broken link somewhere on the skillsforall.com site.
Try sending them a mail and for sure they will fix the problem.
Regards, LG
*** Please Rate All Helpful Responses ***
Hi, I need not only the packet tracer but also(attached)
1) Cybersecurity LabVM Workstation (CSE-LABVM, Security Workstation): Virtual Machine for the Cybersecurity courses
2) Kali Linux: Virtual Machine for the Ethical Hacker course
All links are under this link https://skillsforall.com/resources/lab-downloads?courseLang=en-US But when I click download any of the links, it downloads a Null unnecessary file. Thanks.
This is what I mentioned in my previous post
Also the same situation is for Ethical Hacker Kali Linux Virtual Machine.
Try using the Support link at the bottom of the page https://skillsforall.com/resources/lab-downloads?courseLang=en-US and for sure they will fix the problem.
Regards, LG
[image: image.png]
There is no image attached.
Regards, LG
the issue with download vm solved now, i can download the vm
regardes,
Hello @Usrry Abass ,
try clearing the browsers cache and try the link again https://www.netacad.com/portal/node/4035
In my case it worked.
Regards, LG
still have the same issue regarding downloading the ethical hacker vm from
lab resources .
Have you tried another browser?
Regards, LG
the issue solved
Gopinath_Pigili
Hello bdsmrahman ,
I suggest you to  download packet tracer directly from Netacademy web site...(but login is required), it worked for others.
https://www.netacad.com/portal/resources/packet-tracer
Best regards
******* If This Helps, Please Rate *******
