12-03-2014 03:26 PM
I've set everything up as instructed on my router and on my local settings. Cleared DNS cache and Resolver cache. I get the orange check mark at https://www.opendns.com/welcome/ but I have no network stats on the website.
12-03-2014 04:00 PM
How long ago did you set this up? The stats available with the graphs at the top of the page are for the previous day - See where it says "Recent activity (all networks, last day)." If you click one of the options at the left side of the page, such as Total Requests you can see information for the current day.
Under settings for your network, in "Stats and Logs", do you have "Enable Stats and Logs" checked? I think it's checked by default, but without it no stats will be saved for you.
If you want a further check of if OpenDNS is working correctly you could try to access a website for which you've blocked the domain through either a category or a blacklist.
12-03-2014 04:08 PM
Set it up about an hour ago. Recent activity shows zero activity. Stats and logs is enabled. Blocked a url and I still have access to it.
12-03-2014 05:13 PM
12-03-2014 11:25 PM
"Set it up about an hour ago."
Stats are not real-time. Initially it takes 24 hours, going further 1-3 hours for the stats to appear.
