Not Blocking internetbadguys.com
jeb.jr
I've had OpenDNS configured on my router for a while and it was working.  One day I decided to check and it's not working.  It won't even block internetbadguys.com.
I've made sure that my dynamic IP is correct.  I've rebooted my router and my computer.  Still no joy.
7 Replies 7
rotblitz
Level 6
Level 6
Do you use OpenDNS at all?   http://welcome.opendns.com/
If not, check on your router if the OpenDNS resolver addresses are still configured.
Still problems?  Copy & paste the complete plain text outputs of the following diagnostic commands to here:
nslookup -type=txt debug.opendns.com.
nslookup whoami.akamai.net.
netsh interface ipv4 show config
underwood2000
hi
i have this problem
rotblitz
Level 6
Level 6
But "plain text" looks differently...
Why does the 'netsh' command raise an error?  What strange Windows version do you run?  Is it Windows 98 or so?
Also, I cannot see that you have a problem with OpenDNS.  If you didn't disable "Phishing Protection" under your dashboard's Security settings, then internetbadguys.com should cause a block page being raised.  What plain text does the following command return?
nslookup www.internetbadguys.com.
And what message is shown at http://welcome.opendns.com/ ?  And what browser are you using?
underwood2000
windows xp service pack 3
http://welcome.opendns.com is ok and show me checkpoint .
phishinh protection is enable on the securtiy page
but nslookup internetbadguys.com is not good
rotblitz
Level 6
Level 6
"windows xp service pack 3"
For Windows XP the command is:
netsh interface ip show config
And still, plain text is different.
Server:         192.168.178.1
Address:        192.168.178.1#53
Non-authoritative answer:
Address: 146.112.61.108
As you can see, I get the same good result.  This 146.112.61.108 is hit-phish.opendns.com, so this domain is being blocked for you, because you do not get its real IP address.  If you still can visit it with a browser, then your browser circumvents your settings, maybe with a browser plugin or add-on, or because you didn't flush your browser cache or local resolver cache.  Therefore I asked what browser you are using, but you didn't say it.
underwood2000
i user firefox and seamonkey browser
i clean all history and flush dns but internetbadguys.com opened
rotblitz
Level 6
Level 6
This still isn't plain text. :(
It must be something with your browsers, because your configuration and the OpenDNS behavior and result are correct.  You can check at https://www.dnsleaktest.com/ and http://dnsleak.com/ what DNS service your browsers may be using.  But I don't know what to do to make OpenDNS work with your browsers.  Maybe someone else?
