10-05-2017 08:48 PM
I've configured my PC's DNS to 208.67.222.222 and 208.67.222.220. But opendns is still not blocking sites. I've already flushed my dns and also cleared my browsing data but its still allowing me to access sites that are supposed to be blocked in my settings. I've checked in http://welcome.opendns.com/ and it says welcome to open dns with orange check mark so I know I am realy using opendns. I've typed nslookup -type=txt debug.opendns.com and got this result
Server: UnKnown
Address: fe80::1
*** UnKnown can't find debug.opendns.com: Non-existent domain
help guys
10-05-2017 11:46 PM
OpenDNS blocks domains, but you don't send your DNS traffic to OpenDNS. You have configured 208.67.222.222 and 208.67.220.220, but you're actually using
Server: UnKnown
Address: fe80::1
Pretty different, what? You must configure ::ffff:d043:dedc and ::ffff:d043:dcde as DNSv6 server addresses in the IPv6 properties of your computer (or router?) too.
10-07-2017 11:31 AM
So i should also configure ipv6.. But I'm using IPV4. Sorry I'm not realy that techy. But i'll follow your advice. I'll change ipv6 address. Thanks for the response
10-08-2017 08:36 PM
You are using BOTH IPv6 and IPv4. If you want OpenDNS to work properly and consistently for you that means configuring things so that all of your DNS traffic reachess OpenDNS, which is what rotblitz suggestions accomplish. Otherwise your choice is to disable IPv6 or to live with inconsistent and unreliable blocking by OpenDNS.
10-08-2017 11:23 PM
12-08-2018 02:28 PM
thanks rotblitz! That solved it for me.
12-10-2018 01:56 AM
Welcome!
02-24-2019 12:26 PM
It stopped working for me again. Here is some more info: https://support.opendns.com/hc/en-us/community/posts/360018327183-Web-filter-not-working?page=1#community_comment_360004604091
Appreciate the help. Thanks.
02-24-2019 03:01 PM
It really does not make sense to generate multiple posts about the same issue... :(
10-22-2019 05:21 AM
Hey bro I am having the same problem...can You help me out :|
Here are the command results:
nslookup -type=txt debug.opendns.com. 208.67.220.220
Server: resolver2.opendns.com
Address: 208.67.220.220
opendns.com
primary name server = auth1.opendns.com
responsible mail addr = noc.opendns.com
serial = 1571723470
refresh = 16384 (4 hours 33 mins 4 secs)
retry = 2048 (34 mins 8 secs)
expire = 1048576 (12 days 3 hours 16 mins 16 secs)
default TTL = 2560 (42 mins 40 secs)
nslookup -type=txt which.opendns.com.
Server: resolver1-fs.opendns.com
Address: 208.67.222.123
Non-authoritative answer:
which.opendns.com text =
"r4.mum1"
opendns.com nameserver = auth1.opendns.com
opendns.com nameserver = auth2.opendns.com
opendns.com nameserver = auth3.opendns.com
auth1.opendns.com internet address = 208.69.39.2
auth1.opendns.com AAAA IPv6 address = 2620:119:30::53
auth2.opendns.com internet address = 146.112.60.53
auth2.opendns.com AAAA IPv6 address = 2a04:e4c0:53::53
auth3.opendns.com internet address = 208.69.39.2
nslookup whoami.akamai.net.
Addresses: 2404:6800:4000:1003::102
172.217.34.195
nslookup pornhub.com
Address: 66.254.114.41
netsh interface ipv4 show config
Configuration for interface "Ethernet"
DHCP enabled: Yes
InterfaceMetric: 5
DNS servers configured through DHCP: None
Register with which suffix: Primary only
WINS servers configured through DHCP: None
Configuration for interface "Local Area Connection* 1"
DHCP enabled: Yes
InterfaceMetric: 25
Configuration for interface "Local Area Connection* 2"
DHCP enabled: Yes
InterfaceMetric: 25
Configuration for interface "Wi-Fi"
DHCP enabled: Yes
IP Address: 192.168.0.104
Subnet Prefix: 192.168.0.0/24 (mask 255.255.255.0)
Default Gateway: 192.168.0.1
Gateway Metric: 0
InterfaceMetric: 50
Statically Configured DNS Servers: 208.67.222.123
208.67.220.123
Configuration for interface "Loopback Pseudo-Interface 1"
DHCP enabled: No
IP Address: 127.0.0.1
Subnet Prefix: 127.0.0.0/8 (mask 255.0.0.0)
InterfaceMetric: 75
Statically Configured DNS Servers: None
Statically Configured WINS Servers: None
It'll be really great if u could help me @rotblitz
10-22-2019 11:07 AM
Something redirects your DNS traffic to another DNS service, most likely your ISP. Call your ISP to opt out from this redirection.
10-22-2019 12:09 PM
What to ask them exactly? Sorry but I don't have much knowledge related to networking and stuffs @rotblitz
10-22-2019 12:21 PM
You ask that you want to opt out from their DNS redirection because you want to use a 3rd party DNS service.
10-22-2019 12:42 PM
Thanks man for your help :) You're awesome! @rotblitz
10-22-2019 12:51 PM
Can I check myself through any command if my ISP is performing any DNS redirection or can I stop it myself? @rotblitz
