OpenDNS not blocking
warhound608
OS: Windows 10
Router: Cisco Linksys
DNS is setup on router and workstation.
IP address is configured correctly: 76.107.120.119
I have restarted router and PC and flushed DNS.
Output of "nslookup -type=txt debug.opendns.com.":
Microsoft Windows [Version 10.0.15063]
(c) 2017 Microsoft Corporation. All rights reserved.
C:\Users\******>nslookup -type=txt debug.opendns.com.
Server: resolver1.opendns.com
Address: 208.67.222.222
*** resolver1.opendns.com can't find debug.opendns.com.: Non-existent domain
When I go to :https://www.opendns.com/welcome/
I get the oops splash page and am told I haven't configured it yet but on the OpenDNS Updater v2.2.1 software, I am told that I am using OpenDNS.
rotblitz
Level 6
Level 6
Do you have Avast with the "Real Site" option enabled?  Disable it!
If it is not this, then it seems your ISP redirects your DNS traffic to their own DNS service.  You may be able to circumvent this restriction by using https://dnscrypt.org/
warhound608
Thanks, I used the dnscrypt software and it worked.
