OpenDNS works only using LAN
bruno97
HI. I just set OpenDNS on my router (Asus N55U firmware version 3.0.0.4.376_2736 (Annex A)) and as long as it is connected with my pc via lan it works perfectly but when i switch to wireless there is no more OpenDNS. I tried resetting the router and starting all over again but it didn't worked, also tried restating my pc several times but there were no changes.
To configure my router i followed this guide (https://support.opendns.com/entries/38499760-Configuration-for-ASUS-RT-AC68U         ) as the interface of the router in the guide is similiar to mine.
mattwilson9090
Level 4
Level 4
When you say your PC is connected via LAN do you mean it is connected to the router with an Ethernet cable? When you say switch to wireless do you mean using a WiFi connection to the same router?
Assuming that you can answere both of those questions with a yes, please provide full text outputs of the command "ipconfig /all" when your PC is connected "via lan" and again when it is connected via wireless. You could paste the results directly into the comment windows here, or share a screen with the "attach file" button below the comment window (screenshots shared via a file sharing service might be blocked with the OpenDNS settings that some of the people reading and trying to help you here might be using).
bruno97
Yes, i meant that openDNS works only when i connect my PC to internet using the ethernet cable. When i try to connect it using WiFi it doesn't.
Here is the log using WiFi (sorry but it is in italian):
C:\WINDOWS\system32>ipconfig /all
Configurazione IP di Windows
Nome host . . . . . . . . . . . . . . : Bruno-PC
Suffisso DNS primario . . . . . . . . :
Tipo nodo . . . . . . . . . . . . . . : Ibrido
Routing IP abilitato. . . . . . . . . : No
Proxy WINS abilitato . . . . . . . . : No
Scheda Ethernet Ethernet:
Stato supporto. . . . . . . . . . . . : Supporto disconnesso
Suffisso DNS specifico per connessione:
Descrizione . . . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Indirizzo fisico. . . . . . . . . . . : 40-16-7E-0D-50-CB
DHCP abilitato. . . . . . . . . . . . : Sì
Configurazione automatica abilitata : Sì
Scheda LAN wireless Connessione alla rete locale (LAN)* 2:
Descrizione . . . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Indirizzo fisico. . . . . . . . . . . : AC-7B-A1-74-04-BA
Scheda Ethernet Ethernet 3:
Descrizione . . . . . . . . . . . . . : VirtualBox Host-Only Ethernet Adapter #2
Indirizzo fisico. . . . . . . . . . . : 08-00-27-00-18-A9
Indirizzo IPv6 locale rispetto al collegamento . : fe80::accc:5e9c:d6e2:7f9d%10(Preferenziale)
Indirizzo IPv4 configurazione automatica : 169.254.127.157(Preferenziale)
Subnet mask . . . . . . . . . . . . . : 255.255.0.0
Gateway predefinito . . . . . . . . . :
IAID DHCPv6 . . . . . . . . . . . : 604504103
DUID Client DHCPv6. . . . . . . . : 00-01-00-01-1D-1C-A0-D2-40-16-7E-0D-50-CB
Server DNS . . . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
NetBIOS su TCP/IP . . . . . . . . . . : Attivato
Scheda Ethernet Ethernet 2:
Descrizione . . . . . . . . . . . . . : TAP-Windows Adapter V9
Indirizzo fisico. . . . . . . . . . . : 00-FF-24-8F-F7-C6
Scheda LAN wireless Wi-Fi:
Descrizione . . . . . . . . . . . . . : Intel(R) Dual Band Wireless-AC 7260
Indirizzo fisico. . . . . . . . . . . : AC-7B-A1-74-04-B9
Indirizzo IPv6 locale rispetto al collegamento . : fe80::990a:abb8:786d:f56f%5(Preferenziale)
Indirizzo IPv4. . . . . . . . . . . . : 192.168.1.63(Preferenziale)
Subnet mask . . . . . . . . . . . . . : 255.255.255.0
Lease ottenuto. . . . . . . . . . . . : giovedì 20 agosto 2015 18:01:36
Scadenza lease . . . . . . . . . . . : sabato 22 agosto 2015 11:52:07
Gateway predefinito . . . . . . . . . : 192.168.1.1
Server DHCP . . . . . . . . . . . . . : 192.168.1.1
IAID DHCPv6 . . . . . . . . . . . : 78412705
Server DNS . . . . . . . . . . . . . : 8.8.8.8
Here is the one using the Ethernet cable instead :
Indirizzo IPv6 locale rispetto al collegamento . : fe80::98ac:84ab:fe51:ba02%14(Preferenziale)
Indirizzo IPv4. . . . . . . . . . . . : 192.168.1.192(Preferenziale)
Lease ottenuto. . . . . . . . . . . . : venerdì 21 agosto 2015 12:06:24
Scadenza lease . . . . . . . . . . . : sabato 22 agosto 2015 12:06:23
IAID DHCPv6 . . . . . . . . . . . : 222303870
Server DNS . . . . . . . . . . . . . : 192.168.1.1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
rotblitz
Level 6
Level 6
"Server DNS . . . . . . . . . . . . . : 8.8.8.8"
The problem is that you have Google DNS configured for your WLAN connection.  You'll want to set it to obtain DNS server addresses automatically via DHCP from the router, same as for your ethernet connection.
