Where to enter Bypass codes?
jrob09
Hi community,
I was hoping this would be self explanatory - but where on earth do you enter bypass codes?
Every page that is blocked doesn't have any field for you to enter them. Am I misunderstanding the point on how these are supposed to work?
mattwilson9090
Level 4
Level 4
If you are using OpenDNS Home you don't enter them anywhere since that isn't a feature of that product. You'd need to be using one of the pay products, such as Umbrella.
jrob09
Sorry, I should have mentioned we are using umbrella.
I have installed the client on my PC. It's rolled out to about 250 desktops - but cannot find out where to enter these bypass codes. I've tried googling etc. without much joy.
Any idea?
Thanks!
rotblitz
Level 6
Level 6
You are in the OpenDNS forum but certainly wanted to visit the Umbrella forum:
https://support.umbrella.com/hc/en-us/search?utf8=%E2%9C%93&query=bypass+codes
And if this does not help, your best bet is to raise a support ticket with Cisco Umbrella.
https://support.umbrella.com/hc/en-us/requests/new
jrob09
Apologies and thank you for pointing me in the right direction.
