15540 CPU redudancy
swilli
The 15540 has two CPU in order to have a redundancy in case one fails.
We would like to know if there is a way to configure the Primary/Secondary, e.g. having the Primary CPU alwyas in Slot 6 and the Secondary in Slot 7, after a Power On Reset.
If there isn't, can somebody explain the rule how the Primary gets selected, because we found out that there is no evidence which one gets Primary after a Power On Reset.
Thanks in advance and regards Steff
pradeepde
Level 5
Level 5
Use the following commands to monitor processor card redundancy operations.
show redundancy capability
show redundancy clients
show redundancy counters
show redundancy history
show redundancy running-config-file
show redundancy states
show redundancy summary
For more information : http://www.cisco.com/en/US/products/hw/optical/ps2011/products_command_reference_chapter09186a008022635d.html#wp1038981
