Cisco Cloud Service Router (CSR) for Public Cloud Discussions
It needs help for a not reset, but a password recovery for Cisco 1921/K9+CON-SNT and ws-c2960-24tc-s v08 switch.How can I do this without losing the hardware settings?I don't have any real experience with this.I sent serial numbers to support, but th...
こんにちは、みんな。現在、Ciscoラック サーバーを 取得してセットアップしようとしていますが、既存のネットワーク インフラストラクチャとの統合プロセスについてお聞きしたいと考えています。具体的には、統合がどの程度シームレスになるか、また互換性に関して注意すべき点があるかどうかについてお聞きしたいと考えています。ネットワーク システムが確立された環境で Cisco ラック サーバをセットアップした経験のある方がいらっしゃいましたら、そのプロセス中に発生したヒントや潜在的な課題があればぜひお聞か...
Hello, I'm Junhyeok Bae from KB Securities in South Korea.Currently, our company subscribes to the Cisco Catalyst 8000v SD-WAN & Router - PAYG - DNA Advantage model on AWS Marketplace.I would like to inquire about the CPU, Memory, and Temperature val...
bjh5098 by Level 1
  • 924 Views
  • 0 replies
Hey everyone,I have a friend who owns a dental lab and is currently facing a cloud issue. They've been experiencing some challenges with their cloud infrastructure and are in need of some expert guidance.That's where the Cisco community comes in. Wit...
Hi, I am trying to bring up CSR1000V as a DMVPN hub in the AWS cloud. Go the basic config on the hub & spoke routers and ping across the public IPs of both the routers. But ISAKMP peering is failing and not able to establish the phase1 between the tw...
ksaridena by Level 1
  • 8889 Views
  • 8 replies
On a CSR100v 17.1 on azure we are able to install azure agent by the command "sudo pip install csr_azure_guestshell" On a CSR100v 17.3.4a we get this error:sudo pip install csr_azure_guestshellsudo: pip: command not found so we tried by:sudo pip3 ins...
