09-27-2014 01:19 PM
I need your help to know what command Can I use to display the power optics from a interface on a switch WS-4507R+E
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASEK9-M), Version 15.0(2)SG6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 31-Oct-12 14:49 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x12CFB978
ROM: 12.2(44r)SG10
Darkside Revision 4, Nexu Revision 12, Fortooine Revision 1.32
Uptime for this control processor is 1 year, 25 weeks, 2 days, 19 hours, 50 minutes
System restarted at 18:25:28 CDT Tue Apr 2 2013
System image file is "bootflash:cat4500e-ipbasek9-mz.150-2.SG6.bin"
And this is the module type:
show module 5
Mod Ports Card Type Model Serial No.
5 12 1000BaseX (SFP) WS-X4612-SFP-E JAE1701091K
NAME: "GigabitEthernet5/2", DESCR: "1000BaseSX"
PID: GLC-SX-MMD , VID: V01 , SN: FNS164809BM
Thank you for your help.
Solved! Go to Solution.
10-09-2014 03:09 PM
Try "sh interface trans details".
09-28-2014 12:46 AM
The command is: sh interface Gi5/2 transceiver properties
10-09-2014 06:13 AM
Leo:
Iam sorry, but i tried to give this command and it does not accepted.
10-09-2014 03:09 PM
10-10-2014 10:12 AM
i TRIED with this command.
Thank for your help.
06-13-2015 12:29 AM
Did you find out how to do this?
06-23-2015 02:05 AM
If you look at table 2 in the link it shows the DOM support on 4500 series. Check the SFP you are using. I tried GLC-SX-MMD and I am also unable to see any details when using show int g0/1 transceiver detail.
Table 2 DOM Support on the Catalyst 4500 Series Switch applies to these module
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/release/note/OL_27991-01.html#pgfId-2674444
