11-11-2014 09:24 AM
We Work in the network that it is based on ONS 15454 for "Transmission".
we used 15454-M-10X10G-LC card for 10G transmission network.
In the client side, Can we connect the client Ports of this card directly to the ws_x6704 Ports ? are there compatible or not ?
with best regards
11-15-2014 11:29 AM
Yes you can, but you need to check PIDs of SFP modules.
- ONS 15454 - Inventory tab in CTC, column Product ID
- Cat 6704 - cli command "show inventory"
Then need to check standards of this SFP.
Log in to Community
