10-13-2014 02:14 PM
I am having problems trying to long into the old model of the ONS-15454. I have a windows 7, when I try to log on with CTC I have to download Ver 9.215-012-k2045 because the company does not want to upgrade but it takes a long time to download, when I mean long is long, almost 12hrs to download and then it does not work, I have clear the cache and start all over and the same thing happens. I could log into the new version of the 15454 with Ver.-10.0.1 with no problem but not a chance with the old 15454 model.
Has anyone experience similar symptoms? Any help with be appreciated.
Solved! Go to Solution.
12-18-2014 10:13 AM
in windows-7 there is a caveat, we have to execute two commands,
also check if you have right Java version, Java Version 7 with update 45 works for all releases.
check this link, Method-3 for commands.
http://www.cisco.com/c/en/us/support/docs/optical-networking/ons-15454-series-multiservice-provisioning-platforms/116642-technote-ctc-00.html
also go through this link, it can be useful.
12-18-2014 10:13 AM
