Question about 1FE-TX module and router 2811
rafalnow
I have a router 2811 and 2621XM. A 1FE-TX module is installed on the 2621XM. What can happen when I install a module on router 2811. Can I damage port on router 2811. Is it worth to try to connect module to 2811?
Please help.
 Thank you
johnd2310
Level 8
Level 8
The module is supported in 2800 routers and should work in a 2811 router. Make sure both routers are powered off when you  transfer the module.
https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/nm/hardware/installation/guide/OvrNetM.html
John
**Please rate posts you find helpful**
HI
Everything works correctly.
Thank you very much !!
You are the BEST !!!
Thank you again.
Hello
It's me again.
I have a question.
I have two routers 2811 with the same IOS. The 1FE-TX module in one router works fine but the same module in the other router causes a PCI bus error. IOS systems on both routers are the same.
What could be wrong?
