04-03-2017 12:58 PM
How do you test a SFP in a 2960X switch? In a 2960G I can loop the TX to RX on a GLC-LH-SM and the SFP and the port would go green. In the 2060X it goes amber. Anybody know what was changed to prohibit this capability?
04-03-2017 07:15 PM
If you are using a short patch lead to do that test make sure you use a fibre attenuator to introduce some loss so the SFP doesn't kill itself.
04-06-2017 07:57 PM
Usually, it will work if the SFP can operate over 2960X switch. Never met this problem before, maybe it is the issue of the 2060X.
