XFP-10GLR-OC192SR vs SFP-10G-LR-CURV
I am facing a XFP-10GLR-OC192SR mounted on a Cisco ASR 1004 against a SFP-10G-LR-CURV mounted on a Cisco Catalyst 4500 Switch and I cant get line protocol up. They are connected using a 6Km SM Fibre.
This is relevant output from ASR 1004
gfs-core-router02#show interfaces tenGigabitEthernet 1/0/0
TenGigabitEthernet1/0/0 is down, line protocol is down
Hardware is SPA-1X10GE-WL-V2, address is f8c2.8894.0840 (bia f8c2.8894.0840)
Description: ##### Reserved for future 10G Uplinks #####
MTU 1500 bytes, BW 9953280 Kbit/sec, DLY 10 usec,
Keepalive not supported
Full Duplex, 10000Mbps, link type is force-up, media type is 10GBase-LR
output flow-control is on, input flow-control is on
Last input never, output never, output hang never
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 17 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
gfs-core-router02#show hw-module subslot 1/0 transceiver 0 status
The Transceiver in slot 1 subslot 0 port 0 is enabled.
Module temperature = 26.710 C
Transceiver Tx bias current = 26700 uAmps
Transceiver Tx power = -2.7 dBm
Transceiver Rx optical power = -13.9 dBm
And this from the 4500 Switch
core-sw01#show interfaces tenGigabitEthernet 1/1/5
TenGigabitEthernet1/1/5 is down, line protocol is down (notconnect)
Hardware is Ten Gigabit Ethernet Port, address is 0462.7399.3f84 (bia 0462.7399.3f84)
Description: ###LEVEL3_IP_TRANSIT###
MTU 9070 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, Auto-speed, link type is auto, media type is 10GBase-LR
input flow-control is off, output flow-control is off
Last clearing of "show interface" counters 3w4d
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Received 0 broadcasts (0 multicasts)
0 output errors, 0 collisions, 2 interface resets
core-sw01#show interfaces tenGigabitEthernet 1/1/5 transceiver
ITU Channel not available (Wavelength not available),
Transceiver is internally calibrated.
If device is externally calibrated, only calibrated values are printed.
++ : high alarm, + : high warning, - : low warning, -- : low alarm.
NA or N/A: not applicable, Tx: transmit, Rx: receive.
mA: milliamperes, dBm: decibels (milliwatts).
Optical Optical
Temperature Voltage Tx Power Rx Power
Port (Celsius) (Volts) (dBm) (dBm)
Te1/1/5 25.8 3.26 -1.3 -9.3
As it can be seen, both modules have inside operational range light signal.
I think the problem is in the XFP-10GLR-OC192SR that is working in SONET mode rather than in ETHERNET (note the BW 9953280 Kbit/sec in the interface)
So is there any way to force the interface to work in ETHERNET mode?
Kind regards,
Miguel
Marvin Rhoads
I think you may be right.
Try changing the mode with the following configuration mode command:
hw-module subslot 1/0 enable LAN
Reference: http://www.cisco.com/c/en/us/td/docs/interfaces_modules/shared_port_adapters/configuration/ASR1000/ASRspasw/ASRcfget.html#pgfId-1274430
Marvin Rhoads
It worked like a charm. Link is up. Thank you very much!!! Miguel
