10-23-2014 08:45 AM
I need help with 100G IPoDWDM with ASR9000 ( DWDM bundle )
We have simple setup
ASR9000 -----100G-SR------ONS15454-------DirectFiber with attenuation ( using 1560,20 ) ------- ONS15454-----100G-SR------- ASR9000.
This is lab setup but in the future with will work as alien lambda (1560,20 ) for customer MUX/DEMUX.
But now we have just direct fiber patchcords with attenution in the LAB.
I have problem with 100G-SR optics with MPO cable - links between ASR9000s and ONS15454s never up.
Loop connection ( just for test ) with MPO cable between two asr9000 100G interface working well – link is up.(I can ping)
I can’t make link UP in any way with ONS15454 100G transponder card ( with 100G SR optics ) connected to asr9000 100G port.
DWDM side optics works well I see TX/RX power and other statistic – all are green.
I am sending and receving OTN string so this hopefuly working well.
I provisioned "Provisionable Patchcord" between both ONS15454 chassis and both 100G cards trunk port ( is green in CTC )
I made Circuit OTHCC between 100G cards 100G Ethernet client port on both side.
Still I don't see any RX/TX power on 100G side ( on any LANE in SR Optics )
Please share you experience with running up such configuration ?
Anybody had problem with 100-SR Optics ?
Any tricky part in this configuration ?
FYI
To rull out the faulty part I have made
- changed MPO cables
- changed SR optics in ONS and also CFP in asr9000 ( I have few such boxes )
- changed 100G cards and also diferrent ports on asr9000
- changed ONS chasiss and also ONS 100G Transpoder card
10-26-2014 01:37 AM
- Try create OCHCC not 100G, try use OTU4 may be it will helpful. And what is the status of ASR 9k port in CTC( I mean in CTC network view and choose Show Router Port Status > rack/slot/module/port.)
- Are circuit up inside DWDM network? Try to make photonic test in Properties of OCH-Trail. May be you didn't Lanch ANS or problem inside network.
- Also Try generate traffic! not ping.
03-09-2016 11:05 PM
I currently have this same issue how did you end up fixing this?
