I'm having all sorts of issues trying to get an Acces Point talking to a switch.
I have the following:
- WS-C3560V2-24PS Catalyst 3560
- GLC-SX-MM= SFP Adapter
- AIR-PWRINJ-FIB Media Converter
- AIR-AP1242AG-N-K9 Access Point
- (MT-RJ to LC patch cable)
Here's what happens:
- The AP powers up via Ethernet
- The Ethernet LED is on for the AP (Status light is blue/green)
- The MC Shows both the Fibre and Power LED's
- The Switch does not show the Green LED where the SFP is plugged into
I've tried a few different configs with the switch and the Gigabit ports, but nothing I do seems to work.
Also tried other AP and MC.
Have confirmed that the AP works ok via Ethernet straight from the Switch.
And before you ask, yes, I do need to run the AP via the MC (due to distance).
I'd really appreciate any help on this one.
