3560 w/ SFP to AIR-PWRINJ-FIB to 1242AG issue
LordRikiller
I'm having all sorts of issues trying to get an Acces Point talking to a switch.
I have the following:
  • WS-C3560V2-24PS Catalyst 3560
  • GLC-SX-MM= SFP Adapter
  • AIR-PWRINJ-FIB Media Converter
  • AIR-AP1242AG-N-K9 Access Point
  • (MT-RJ to LC patch cable)
Here's what happens:
  • The AP powers up via Ethernet
  • The Ethernet LED is on for the AP (Status light is blue/green)
  • The MC Shows both the Fibre and Power LED's
  • The Switch does not show the Green LED where the SFP is plugged into
I've tried a few different configs with the switch and the Gigabit ports, but nothing I do seems to work.
Also tried other AP and MC.
Have confirmed that the AP works ok via Ethernet straight from the Switch.
And before you ask, yes, I do need to run the AP via the MC (due to distance).
I'd really appreciate any help on this one.
ricardoglzs
I have a very similar issue.
  • WS-C3750G-12S
  • AIR-LAP1242AG-A-K9 Access Point
Happend the same to me also.
The power injector recognize the link and the AP, but the switch in my case with a GBIC does not turn on.
Did you ever make it work?
