Hello everyone!Does anyone know if these 2 fiber optic SFPs are compatible with each other?We have and old HP J4853A transceiver which is 802.3u and Cisco SFP LX Module which is 802.3zThank you!
We had a power outage that took down a ONS 15454 in a remote facility. Upon restoring power and powering-up the unit, it shows up in CTC as grey with "Uknown2" as the name.I had someone reseat the TCC card, but it still comes up as unknown.Has anyone...
i have 2 test switches setup in a LAB, each switch connecting to each over CWDM-Mux-8A, using various differenet wave CWDM SFPs on both switches, and i have tried it using different ports on the Cisco switch, different CWDM MUX-8A, different CWDM S...
In other terminal like 870 I use command "show dsl interface atm 0" but now we have a cisco 892 with OF acces. How can I cheeck the current line speed?Thanks
Hi,I am new to optical networ. Learning DWDM and came cross this concept. Does anyone know what is the differences between ROADM and OADM?Thanks,Bo
hello all;i have PA-MC-STM-1SMI in my 7206 VXR; and i need to configure some link but not E1for first i need to configure a grouped VC3 in one interface,and i have 34M link between 2sites so 14VC12, and i need to have just one interface with 34 M ba...
Can I use the 1 x SFP port for Single mode fiber and the other SFP port for Multi mode fiber to complete the ring Network?
We are trying to run 10GB fiber between two network stacks. The network stacks contain a combination of 3750Gs and 3750Xs. In the 3750Xs that we are trying to connect via fiber, we have the following inventory:C3KX-NM-10G2x SFP-10G-LRMOne of the 10G ...
Hello,I hope there are some people out there who can help me.If I set up a LACP or PAgP channel between two 6504-E with a optical connection over a CWDM (Transmode TS Series, passive CWDM) LACP and PAgp do not come up. Using the command "show etherch...
Hello, I've got a problem with my Cisco ONS 15305. When started, it reboots, and the following message shows up: BOOTSTRAP SW V2.0 Date 18-Mar-2003 Time 16:33:44BUS test started.BUS test SUCCESS !REASON FOR BOOT IS: SOFTWARE WATCHDOG RESETTHE INT...
I have a 15454 ONS network with 2 nodes. SW vers 4.1, TCC cards, and adding a fourth Ds3 card to shelf. I deleted two unused OC3 circuits to clear 6 STS1's to cross-connect the new ds3 cards on each end. I keep getting "IllegalArgumentException: type...
Hi All,While having conversation with Cisco engineer, he said its in future road map(but not commited) to support DOM over SNMP MIBs and DOM on CLI is supported as of now. But module compatiblity has no information on 2960S DOM support and Release no...
Y cabling the optical protected uplink 150M circuit off the MUXMUX ---< Primary and seconday routerCan this be done on the Cisco routers?
Hi All, Can I use FET-10G to connect betweet Nexus 2K FEX and servers. Or it's just for FEX connection between N2K and parent switch? Thanks in Advance!!
Our ONS-15454 chassis are approaching 10 years old and we have started to see fan failures. But when a fan fails, it does not create an alarm within the CTC or generate a remote alarm. We do see the "Fan Fail" light on the fan tray illuminate, but ...
Subject | Author | Posted |
02-03-2025 08:10 AM | ||
10-04-2024 12:50 PM | ||
09-24-2024 09:19 PM | ||
07-25-2024 01:25 PM | ||
05-05-2024 05:19 AM |
