40 Gig troubleshooting 2 channels 1 side don't show light
j2sw
Folks,
I have a 2 Cisco switches with 40 Gig optics in each.  One side sees light on all 4 channels and everything looks good.  The other side does not see light on 2 of the 4 channels.  Where to start troubleshooting? I have tried different ports on the switches.
11 Replies 11
marce1000
       - Try changing  polarity  (flip), on a fiber patch cord ,
 M.
show interfaces transceiver details <<- share this
j2sw
Side A
thernet1/53
transceiver is present
type is QSFP-40G-ER4
name is CISCOSOLIDOPTICS
part number is QSFP-40G-ER4-LC
revision is 1A
nominal bitrate is 10300 MBit/sec per channel
    Link length supported for 9/125um fiber is 40 km
    cisco id is 13
    cisco extended id number is 204
Lane Number:1 Network Lane
           SFP Detail Diagnostics Information (internal calibration)
                Current              Alarms                  Warnings
                Measurement     High        Low         High          Low
  Temperature   48.61 C        80.00 C    -10.00 C     75.00 C       -5.00 C
  Voltage        3.19 V         3.70 V      2.90 V      3.59 V        3.00 V
  Current       45.96 mA       85.00 mA    10.00 mA    80.00 mA      15.00 mA
  Tx Power       0.24 dBm       5.49 dBm   -4.50 dBm    4.99 dBm     -4.00 dBm
  Rx Power     -10.17 dBm      -5.00 dBm  -25.22 dBm   -7.01 dBm    -22.21 dBm
  Transmit Fault Count = 0
  Note: ++  high-alarm; +  high-warning; --  low-alarm; -  low-warning
Lane Number:2 Network Lane
  Current       46.22 mA       85.00 mA    10.00 mA    80.00 mA      15.00 mA
  Tx Power       1.30 dBm       5.49 dBm   -4.50 dBm    4.99 dBm     -4.00 dBm
  Rx Power     -10.86 dBm      -5.00 dBm  -25.22 dBm   -7.01 dBm    -22.21 dBm
Lane Number:3 Network Lane
  Current       44.01 mA       85.00 mA    10.00 mA    80.00 mA      15.00 mA
  Tx Power       0.54 dBm       5.49 dBm   -4.50 dBm    4.99 dBm     -4.00 dBm
  Rx Power     -10.04 dBm      -5.00 dBm  -25.22 dBm   -7.01 dBm    -22.21 dBm
Lane Number:4 Network Lane
  Current       43.14 mA       85.00 mA    10.00 mA    80.00 mA      15.00 mA
  Tx Power       1.14 dBm       5.49 dBm   -4.50 dBm    4.99 dBm     -4.00 dBm
  Rx Power      -9.50 dBm      -5.00 dBm  -25.22 dBm   -7.01 dBm    -22.21 dBm
IPLVINE733-NEXUS100GIG_SW-01#
j2sw
Side B
Ethernet2/1
    revision is 1A
    cisco id is 13
  Temperature   20.50 C        80.00 C    -10.00 C     75.00 C       -5.00 C
  Voltage        3.37 V         3.79 V      2.70 V      3.70 V        2.79 V
  Current       28.46 mA      110.00 mA     5.00 mA   100.00 mA      10.00 mA
  Tx Power       1.93 dBm       5.99 dBm   -1.00 dBm    4.99 dBm      0.00 dBm
  Rx Power          N/A        -4.00 dBm  -25.22 dBm   -6.00 dBm    -22.21 dBm
  Current       30.25 mA      110.00 mA     5.00 mA   100.00 mA      10.00 mA
  Tx Power       1.41 dBm       5.99 dBm   -1.00 dBm    4.99 dBm      0.00 dBm
  Rx Power      -3.94 dBm ++   -4.00 dBm  -25.22 dBm   -6.00 dBm    -22.21 dBm
  Current       27.65 mA      110.00 mA     5.00 mA   100.00 mA      10.00 mA
  Tx Power       1.66 dBm       5.99 dBm   -1.00 dBm    4.99 dBm      0.00 dBm
  Rx Power      -7.09 dBm      -4.00 dBm  -25.22 dBm   -6.00 dBm    -22.21 dBm
  Current       29.87 mA      110.00 mA     5.00 mA   100.00 mA      10.00 mA
  Tx Power       1.54 dBm       5.99 dBm   -1.00 dBm    4.99 dBm      0.00 dBm
what the length of cable you use ??
if the length is two short
THIS IS MY OPIONON NOT SUGGESTION SO FROM YOUR SIDE MAKE MORE CHECK ABOUT THIS POINT
then check use Attenuator
What Fiber Attenuator Do You Use? LC Attenuator or SC? | FS Community
j2sw
This is a dark fiber path. It is a 10-mile path.  This is why I am using the ER optics
               >...This is a dark fiber path...
  - Has this fiber ever been tested for 'link integrity' ,
 M.
  Rx Power      -3.94 dBm ++  <<- this make think that the length is short, the recommend length is 40 km and you use 16 km
I am thinking I am going to try an attenuator.  Maybe too hot?
j2sw
fiber is fine. Can run a 10 gig optic over and has been verified with an OTDR
  - According to switch models used , check (SFP) and other compatibility stuff with : https://tmgmatrix.cisco.com/
 M.
