02-15-2022 07:22 AM
I connected a 40GBASE-CR4 Passive Copper Cable, 1m cable between 2 x C9500-24Y4C-E switches, but I don't get a connection. Is there something I am missing?
Solved! Go to Solution.
02-16-2022 07:47 AM
Potentially a bug. Either raise a TAC Case or upgrade to 17.3.5 or 17.6.2.
02-15-2022 07:49 AM
What firmware is the switch running on?
02-16-2022 05:02 AM
Switch#sh ver
Cisco IOS XE Software, Version 17.03.03
Cisco IOS Software [Amsterdam], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 17.3.3, RELEASE SOFTWARE (fc7)
Switch#sh int status
Port Name Status Vlan Duplex Speed Type
Twe1/0/1 connected 1 full 25G SFP-25GBase-SR
Hu1/0/25 notconnect 1 full 40G unknown
02-16-2022 07:47 AM
02-15-2022 07:53 AM
- Check logs of both devices when trying
M.
02-16-2022 05:01 AM
Nothing in the logs -
02-16-2022 09:57 AM
- Make sure the ports are set for autonegotation ,
M.
