40GBASE-SR-BD Compatible Fiber
CiscoMedMed
I have multimode fiber running between two cages at our data center to migrate from one to the other. I have a NX6K on one side and NX9K on the other and 40GBASE-SR-BD for the optics. I can't get the link to come up. I haven't yet changed polarity. I'll try that tomorrow. But I wanted to rule out other issues. The fiber I'm using for jumpering is LC to LC Fiber Patch Cable Multimode Duplex - 3m (9.84ft) - 50/125um OM2. But now I'm not seeing that in the guide below table 1. The cages are only a few meters from each other. I don't have the detailed specs for inter-cage run (maybe 20m) other than it's multi-mode. But if I could rule in or out the OM2 patch cables as likely or not to work that would be a good help. Thanks.
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-9000-series-switches/white-paper-c11-729908.html
https://www.amazon.com/gp/product/B00NFR9GLY/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
2 Accepted Solutions
rather getting Single-mode - get MMF cable if this is nearby and lay and test(by running cable)
check single-mode SFP
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/data_sheet_c78-660083.html
BB
yes that is what my advice, those are not cheap as expected, so running MMF cable grand or 2 will be the maximum, if I were you, I lay my self-ordering cable, if that is my DC, i do many times. (this where sometimes add advantage audit before the order).
BB
7 Replies 7
balaji.bandi
since you mentioned it is less (but still required proper patch lead to work)
Make sure patch connect right way example :
             Light-----------------no Light
SFP1                                                             SFP2
           no light -----------------------Light
Try  speed no nogiation let us know if that works.
here is the distance cisco point of view:
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/gigabit-ethernet-gbic-sfp-modules/datasheet-c78-366584.html
still issue post config both the sides
show run interface x/x
show interface x/x trans
show interface x/x
BB
So I was able to see light in one fiber strand of the pair on each side. Hopeful it was just a polarity issue I swapped A and B on one side. But the SFP still fails top come up.
Nx9K Output:
interface Ethernet1/50
  switchport
  switchport mode trunk
  switchport trunk allowed vlan 1,102,104,254
  no shutdown
CORE01# sho interface eth 1/50 transceiver
Ethernet1/50
    transceiver is present
    type is QSFP-40G-SR-BD
    name is CISCO-AVAGO
    part number is AFBR-79EBPZ-CS2
    revision is 01
    serial number is AVM2035U1FS
    nominal bitrate is 20600 MBit/sec per channel
    Link length supported for 50/125um OM3 fiber is 100 m
    cisco id is 13
    cisco extended id number is 220
    cisco part number is 10-2945-02
    cisco product id is QSFP-40G-SR-BD
Ethernet1/50 is down (Link not connected)
admin state is up, Dedicated Interface
  Hardware: 1000/10000/25000/40000/50000/100000 Ethernet, address: cc16.7eba.920
d (bia cc16.7eba.920d)
  MTU 1500 bytes, BW 100000000 Kbit, DLY 10 usec
  reliability 255/255, txload 1/255, rxload 1/255
  Encapsulation ARPA, medium is broadcast
  Port mode is trunk
  auto-duplex, auto-speed, media type is 40G
  Beacon is turned off
  Auto-Negotiation is turned on  FEC mode is Auto
  Input flow-control is off, output flow-control is off
  Auto-mdix is turned off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  EEE (efficient-ethernet) : n/a
  Last link flapped 00:58:25
  Last clearing of "show interface" counters never
  1 interface resets
  30 seconds input rate 0 bits/sec, 0 packets/sec
  30 seconds output rate 0 bits/sec, 0 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
  RX
    0 unicast packets  42 multicast packets  0 broadcast packets
    42 input packets  5730 bytes
    0 jumbo packets  0 storm suppression bytes
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    0 unicast packets  18 multicast packets  0 broadcast packets
    18 output packets  4244 bytes
    0 jumbo packets
    0 output error  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble  0 output discard
    0 Tx pause
NX6K:
SAC-CORE01# sho inter eth 2/3
Ethernet2/3 is down (Link not connected)
Dedicated Interface
Hardware: 40000 Ethernet, address: 002a.6aa1.4afa (bia 002a.6aa1.4afa)
MTU 1500 bytes, BW 40000000 Kbit, DLY 10 usec
Encapsulation ARPA
Port mode is trunk
full-duplex, 40 Gb/s, media type is 40G
EtherType is 0x8100
Last link flapped 3week(s) 3day(s)
1 interface resets
RX
0 unicast packets 2969981 multicast packets 0 broadcast packets
2969981 input packets 3207579440 bytes
0 Rx pause
TX
0 unicast packets 3179918 multicast packets 0 broadcast packets
3179918 output packets 2086026188 bytes
0 jumbo packets
0 Tx pause
It looks like the problem is the fiber run between the cages was ordered as SINGLE mode and the SFP's are for multi-mode.
Is there a single mode version of 40GBASE-SR-BD? Thank you.
BB
I earlier ran a sanity check between the two 9Ks with multi-mode fiber and those lit up right away. Unfortunately I don't have a long enough patch cable to do the same between cages. But I am getting a quote on running MMF between the cages. I am also getting a quote on 40Gbps single mode SFPs. But on first glance those look very expensive - around $8k or so each?
BB
lolamano98901
Thanks for the tips @balaji.bandi , that will help me for sure!
