C1000 unsupported transceiver
Acar
We have been using OEM sfps for a long time with C2960 series without a problem but we cuurently switch to a C1000 series switch and apperantly this series does not support the allow-unsupported-transceiver command. Does anybody know  a way to use other manufacturers sfps with C1000 series?
marce1000
 - The particular command may have become hidden and not listed in ?-commands-help. You may try to paste it in global-config-mode manually :
 config t
    service unsupported-transceiver
    no errdisable detect cause gbic-invalid
    end
    write mem
 M.
Thanks for your response but sadly we couldnt make it work.
"no errdisable detect cause gbic-invalid" command works as it should but "service unsupported-transceiver" command  is invalid both as the global config and interface command.
Could there be a new way of using OEM or other vendors transceivers?  Maybe cisco changed the command or there is a new command that substittudes for that?
