can i plug CVR-QSFP-SFP10G to 93108TC-FX3P ?
Dear all,
can i plug CVR-QSFP-SFP10G to 93108TC-FX3P ? and use that to connect 10G-SR?
Good luck
KB
9 Replies 9
marce1000
          - Verify with : https://tmgmatrix.cisco.com/
 M.
Hi @marce1000,
https://tmgmatrix.cisco.com/?si=CVR-QSFP-SFP10G not gives any details.
Good luck
KB
 - You can also enter your switch model , it seems to be supported , check attachment :
 M.
Hi @marce1000 ,
I have tried same. but still not mention about converter. i found this on CCW and it is configurable. but need to know when concerning 1G connectivity. if any experienced. Thank you for suggestions
Good luck
KB
balaji.bandi
93108TC-FX3P - its fixed ports with 40/10GB uplink ports. I believe as i remember I had some issue of compatibility, so I have to move to Twinax cable to connect 2 devices (my case)
BB
Hi @balaji.bandi
what was your setup? i need to get 2 x 10G fiber links to out of switch. can you let me know exact devices and modules used?
Good luck
KB
This what i used end up with 40G DAC cable - https://copi.cisco.com/?tpid=163
There is breakout cable from 40G to 4 x10G ports - QSFP-4X10G-AC10M
BB
Thanks @balaji.bandi , i am looking to get 10G optical out from switch. converter available to configure on CCW. but not sure about practical success.
Good luck
KB
I am afraid i can offer any solutions.
BB
