can we configure UDC to both OSC in 15454 M6?
Dears,
can we configure one port UDC to both SFP in the same TNCE. so we can transmitt the UDC traffic to both side west and east.
the objective is, I have a DWDM ring . there is ASR903 router in each access site and i want to make out band management for routers through OSC. to do that i will connect Router RSP port  to the UDC  but there is only one RSP port available.if it is doable, I will connect ASR903 RSP to UDC and from UDC to both OSC (point to multipoint).
aymetwal
Hi Mohammed,
We can configure two OSC on one TNCE, but only one can be used for UDC.
Please check below link for further details:
http://www.cisco.com/c/en/us/td/docs/optical/15000r10_0/ncs/controlcard_nodeconfig/guide/b_ncs_control_card_node_config/b_ncs_control_card_node_config_chapter_011.html?bookSearch=true#ID1287
Ayman
