01-22-2008 09:14 AM
Does anyone know of a way to change the Alarm Severity for exceeded Performance Monitoring thresholds (T-SESS, T-ESS, T-UASL).
I would like to change these from the default severity of 'NA' to Minor or Major. But I don't see these specific conditions in the Alarm Profile Editor?
SW Version: 7.20
management - CTC
01-27-2008 08:55 PM
Try following NTP-A71 located here http://www.cisco.com/univercd/cc/td/doc/product/ong/15400/r72docs/r72pr454/r72malm.htm#wp69747
Rex
01-28-2008 08:35 AM
Rex,
Thank you for the information.
I have been doing a bit more research on the matter. I was hoping that the Alarm Profiles had individual alarm details (can manually modify alarm severity) for the T-ESS, T-SESS, T-UAS, etc. for each of the Performance Monitoring parameters. But it looks like these are all grouped together and fall under the Signal Degrade/Signal Failure alarms for the specific service (DS1, DS3, or OCn) levels.
Thanks again,
Lee
