03-10-2022 09:06 AM
Hi there all- new here so please bear with me.
I was presented a situation which I am struggling to come up with a design for. The end user has an OC3 backbone and we have several 2960X switches deployed and they are needing us to connect a couple to the OC3 via fiber. They clarified that it would need to use OC3 signaling. Is it possible to do this with a 2960 or would a different model switch and GBIC needed? I can trunk a new switch into the host locations but not sure how to get connection even established. They also offered up a GPON interface but no idea if that would include the ONT device or not?? Any guidance would be greatly appreciated.
Solved! Go to Solution.
03-10-2022 09:59 AM
Those transceiver types are designed for use in WAN routers, primarily the ASR 1000 and ASR 9000.
Reference:
https://tmgmatrix.cisco.com/?si=SFP-OC3-LR1
You can use that same tool to see what transceiver types are supported in the 2960X:
https://tmgmatrix.cisco.com/?npf=5
03-10-2022 09:34 AM
No, that's not possible to connect directly. Cisco LAN switches only have Ethernet connection types. Cisco does make ONTs for connection to PON and router interfaces for OC-3 but none of that in their LAN switches as far as I know.
03-10-2022 09:51 AM
Thank you sir for the response! I did find this SFP but not sure what network device it would plug into?? SFP-OC3-LR1
Cisco is very cryptic...I am thinking that I would need something to bring that connection in then drop to a "device" to 2960 connection (looped fiber)?
03-10-2022 09:59 AM
Reference:
