03-11-2022 09:34 AM
Have a question regarding the use of CVR-QSFP-SFP10G modules with 10G sfp(s). I use Cisco 9500-12Q switches, QSFP Based ports. Sometimes we don't breakout the QSFP port and use a CVR-QSFP-SFP10G module is either a 10G or 1G sfp(s). The interface is working but I am not able to run the show interface <Int #> transceiver details command. When I run this command I get the following error:
Diagnostic Monitoring Data is not available.
This question is primarily for people who use Cisco branded CVR-QSFP-SFP10G modules with Cisco Branded 10G sfp(s). I use a Third Party supplier for the CVR-QSFP-SFP10G modules and sfps I use, same 3rd party for both.
If you are using 3rd party Optics and this command gives you an output, I would also love to hear from you.
Solved! Go to Solution.
03-14-2022 03:58 PM
so ended up opening a TAC case to get an answer.
For the 9500-12Q, quoting the TAC Engineer: "CVR-QSFP-SFP10G has no DOM capabilities"
03-11-2022 10:05 AM
Not sure if cisco can give you 3rd part product that outcome.
03-14-2022 01:38 PM
I am more interested if Cisco Branded CVR-QSFP-SFP10G module and 10G sfp on a Cisco switch does give an output when the show interface <interface #> transceiver details command is used.
03-11-2022 05:27 PM
Most important question is: What firmware is the switch on?
03-14-2022 01:39 PM
It is running the latest IOS-XE. But not trying to troubleshoot my switch.
I am asking other people's experiences with these modules and sfp and what output they are getting when running the show interface transceiver commands
03-14-2022 02:56 PM - edited 03-14-2022 02:56 PM
My experience with Cisco-branded optics is a hit-and-miss and, particularly with IOS-XE, is highly reliant on the firmware.
16.12.X, for instance, had so many issues with Cisco-branded optics, however, 3rd party optics work fine.
Currently, I am seeing some bugs being discovered with Cisco-branded QSFP in 17.X.X.
03-14-2022 03:03 PM
Hello Leo,
Have you used the CVR-QSFP-SFP10G modules and 10G sfp? Are you able to tell me if you get an output when you issue the show interface <interface #> transceiver details command?
03-14-2022 03:19 PM
03-14-2022 03:27 PM
1) Cisco 9500-12Q
2) 17.03.04 CAT9K_IOSXE
03-14-2022 03:52 PM - edited 03-14-2022 03:54 PM
CVR means "converter". So what optics is in it?
Output below is from a 9500-32C (IOS-XE version 16.12.5b, Install Mode) & the SFP+ is 3rd party.
Switch#sh idprom int hun 1/0/18 IDPROM for transceiver HundredGigE1/0/18: Description = SFP+ optics (type 130) Transceiver Type: = SFP+ 10GBASE-SR (273) Product Identifier (PID) = SFP-10G-SR Vendor Revision = 4.0 Serial Number (SN) = VE192009912 Vendor Name = CISCO-SO Vendor OUI (IEEE company ID) = 00.53.4F (21327) CLEI code = COUIAM3CAA Cisco part number = 10-2415-01 Device State = Enabled. Date code (yy/mm/dd) = 19/04/02 Connector type = LC. Encoding = 64B66B Nominal bitrate = 10GE (10300 Mbits/s) Minimum bit rate as % of nominal bit rate = not specified Maximum bit rate as % of nominal bit rate = not specified
NAME: "HundredGigE1/0/18-qsa", DESCR: "CVR 10GE SFP "
PID: CVR-QSFP-SFP10G , VID: V02 , SN: DTY24490010 NAME:
"HundredGigE1/0/18", DESCR: "SFP+ 10GBASE-SR"
PID: SFP-10G-SR , VID: V01 , SN: VE192009912
Switch#sh int hun 1/0/18 trans detail ITU Channel not available (Wavelength not available), Transceiver is internally calibrated. mA: milliamperes, dBm: decibels (milliwatts), NA or N/A: not applicable. ++ : high alarm, + : high warning, - : low warning, -- : low alarm. A2D readouts (if they differ), are reported in parentheses. The threshold values are calibrated. High Alarm High Warn Low Warn Low Alarm Temperature Threshold Threshold Threshold Threshold Port (Celsius) (Celsius) (Celsius) (Celsius) (Celsius) --------- ----------------- ---------- --------- --------- --------- Hu1/0/18 26.1 90.0 85.0 -5.0 -10.0 High Alarm High Warn Low Warn Low Alarm Voltage Threshold Threshold Threshold Threshold Port (Volts) (Volts) (Volts) (Volts) (Volts) --------- ----------------- ---------- --------- --------- --------- Hu1/0/18 3.24 3.60 3.50 3.05 3.00 High Alarm High Warn Low Warn Low Alarm Current Threshold Threshold Threshold Threshold Port Lane (milliamperes) (mA) (mA) (mA) (mA) --------- ---- --------------- ---------- --------- --------- --------- Hu1/0/18 N/A 5.8 50.0 40.0 2.0 1.0 Optical High Alarm High Warn Low Warn Low Alarm Transmit Power Threshold Threshold Threshold Threshold Port Lane (dBm) (dBm) (dBm) (dBm) (dBm) --------- ---- --------------- ---------- --------- --------- --------- Hu1/0/18 N/A -2.7 1.0 0.0 -8.3 -9.3 Optical High Alarm High Warn Low Warn Low Alarm Receive Power Threshold Threshold Threshold Threshold Port Lane (dBm) (dBm) (dBm) (dBm) (dBm) --------- ---- --------------- ---------- --------- --------- --------- Hu1/0/18 N/A -3.0 1.0 0.0 -12.1 -13.1
03-14-2022 03:58 PM
03-14-2022 04:06 PM
Are the optics Cisco-branded or not?
03-14-2022 04:26 PM
Cisco TAC replied based on Cisco Branded.
I am using 3rd party.
In any case there is no DOM Support
