Cisco 3900 Router and SFP Modules
I have a Cisco 3925 Router and was kindly given (2) 1g SFP modules for the Router... I plan to use them to feed directly to (2) switches.
- So I know the Media-Type needs to be set, along with the Speed and Duplex.
- What other commands are needed to enable the SFP modules?
balaji.bandi
its combo ports -
Follow the admin guide  - you can use the command - media-type sfp
https://www.cisco.com/c/en/us/td/docs/routers/access/1900/software/configuration/guide/Software_Configuration.pdf
BB
marce1000
 - Nothing special , checkout if the SFP(s) are compatible however : https://tmgmatrix.cisco.com/?npid=941&npid=1441
 M.
balaji.bandi
its combo ports -
BB
Joseph W. Doherty
I'm unsure you must configure speed and duplex as both are implicit (?) once you configure media-type SFP.
