Cisco 9200 SFP module support
U5al3
Dear All,
I just want to know which cisco 9200 switch supported module is use for connecting other devices ... sfp are commonly used as uplinks ... I want one sfp as uplink and rest of the three slots for endpoint devices (workstations)
9 Replies 9
Leo Laohoo
What bandwidth?  SFP or SFP+?
Dear Leo,
Thanks for your reply. Cisco 9200 supports following modules
. 4x1G ports that support 1G SFP modules.
• 4x10G ports that support either 1G SFP or 10G SFP+ modules.
• 2x25G ports that support SFP28 modules.
which one provides best solution, by the way I am looking for SFP+  4x10G ports
Leo Laohoo
C9200-NM-4X supports up to 4 x SFP/SFP+.
It all depends on what particular model you want:
  • 24- or 48-port
  • PoE or non-PoE
  • mGig support or not
  • Fixed optical module or not
Dear Leo,
Thanks for your reply. Please let me know which combo is suitable for my need as I mentioned earlier from 4 of the uplinks 3 are to be used for end devices (PCs) and one for uplink.
Sure if you buy 9200 with uplink  Module has 4 ports
1 you can use uplink to parent switch or core.
3 ports you can use for other server purpose.
BB
thanks for your reply... could you please share any link of cisco for my ref and understanding which module support it.
Look at the datasheet and supported modules, based on the model you choose in Cat 9200.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9200-series-switches/nb-06-cat9200-ser-data-sheet-cte-en.html
BB
Leo Laohoo
You did not answer my question.
All you gave me is "I need 4 x SFP+ ports".  And what about the rest?
Sorry for the inconvenience, yes I need 4 x SFP+ but my question is may i use 3  of them as end device connection(PCs) and 1 as uplink port ??
