날짜: 04-04-2023 04:40 AM
Network Noob here, I have a question about these. This is probably a dumb question, but I am not the brightest bulb in the pack. These GLC-SX-MMD show they are multimode 1000Mbs compatible. My question is can they operate in 100Mbs mode. I have found that the 100/1000BASE-LX SFP for long-reach single-mode fibers work for single-mode, but I also saw that SFP Operation at 100M can be achieved by placing a -5dB attenuator on the SFP. I have been unable to find one, but do they make an attenuator for 1000Mbs multimode SFP? We have a building with multimode fiber nearly everywhere. That includes going to the EUDs. The though is purchase the 1000Mbs SFPs for future use if they change locations or have a life cycle refresh, but the 100 Mbs SFPs are available if there is not a Cisco solution. I would prefer a Cisco solution as it should be compatible with the Cisco devices we plan to install.
해결되었습니다! 솔루션으로 이동.
날짜: 04-04-2023 05:40 AM
>...they are multimode 1000Mbs compatible. My question is can they operate in 100Mbs mode
They can't
>.... can be achieved by placing a -5dB attenuator on the SFP.
Not advisable (if at all possible)
For all Cisco equipment use this app for compatibility info's : https://tmgmatrix.cisco.com/
M.
They can't
M.
날짜: 04-04-2023 05:50 AM
I thought as much, but I wanted to verify before I send my thoughts to the customer. Either they will have to upgrade their internal wiring down the line or purchase new equipment when their life cycle is due. This is a building that uses MT-RJ fiber connectors and Fiber NICs on their present devices. 100Mbs is what they are going to need. Thanks for the compatibility tool link. I needed that.
새로운 아이디어를 발견하고 저장하세요. 전문가 답변, 단계별 가이드, 최근 주제 등 다양한 내용을 확인해 보세요.
처음이신가요? 아래 팁들을 확인해 보세요. 시스코 커뮤니티 사용하기 새 멤버 가이드
